Jump to content
Denon AVR-1909 Subwoofer problem
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   Sequoia93
Sequoia93
  • 2 posts
Posted October 15 2012 - 09:36 AM
So I'm relatively new to home theater systems and recently built a sort of Frankenstein 7.2 system with a Denon 1909. But, recently the subwoofers havent been powering on unless the volume is turned up loud enough, sometimes switching on and off in between songs, or even turning on in the middle of a song. Everything was working fine originally and I can only imagine some setting I haven't figured out yet is causing it. Does anyone have any ideas?
#2 of 4 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,107 posts
  • Real Name:Sam
Posted October 15 2012 - 10:02 AM
Without knowing which subs you got... Nope.
#3 of 4 OFFLINE   Sequoia93
Sequoia93
  • 2 posts
Posted October 15 2012 - 10:35 AM
The receiver is the problem as far as I can tell, it's not sending signal to either subwoofers consistently. Also, the subwoofers are completely different brands but turn on/off at the same times. Regardless I'll add the subwoofer models tonight when I'm home.
#4 of 4 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,107 posts
  • Real Name:Sam
Posted October 15 2012 - 01:36 PM
Typically if the auto on/off of a subwoofer isn't working correctly(and "we" had no way of knowing different brands here)... The gain on the sub is too high, which means the gain from the AVR is too low.
