Jump to content
GETTING AUDIO FROM TV TO SURROUND SOUND
  • Please log in to reply
9 replies to this topic
#1 of 10 OFFLINE   Ider Gerelsuren
Ider Gerelsuren
  • 4 posts
Posted October 01 2012 - 09:05 PM
Hi, I'd like to hook up my samsung led TV to energy classic 5.1 surround sound system
(dont have receiver yet trying to choose one), I never had surround sound system before. So asking from experts.
1.How do I play my audio to Surround Sound from my TV? (note that I'm playing video from my computer to TV, or from external HDD)
2.Also, how do I hook up my cable box(http://www.aminocom....s/aminet-a540-/) to surround system? (Video on TV, Audio on 5.1 system)
And, finally is there any other way to hook up my TV & Cable Box without A/V receiver to my 5.1 system?
Thanks for looking
#2 of 10 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,931 posts
  • Real Name:Sam
Posted October 02 2012 - 03:57 AM
You bought a speaker set that requires an AVR. There are "ways" to use them without an AVR, but it would cost you 10 times more than a basic $200 AVR to accomplish. You connect EVERYTHING to the AVR, then the AVR to the TV. That is how it has been done for 30 years. And, stop thinking "getting sound from your TV" and it makes more sense. In "proper home theater" the TV is nothing more than a display device.
#3 of 10 OFFLINE   Ider Gerelsuren
Ider Gerelsuren
  • 4 posts
Posted October 02 2012 - 07:08 PM
Okay, so can i just hook up my tv to receiver using hdmi? and all my sound will go to speakers?
#4 of 10 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,931 posts
  • Real Name:Sam
Posted October 02 2012 - 09:13 PM
Apparently... "You connect EVERYTHING to the AVR, then the AVR to the TV"... Doesn't mean anything. Sure, go ahead and "hook up TV to AVR" and all sound will come from speakers...
#5 of 10 OFFLINE   Al.Anderson
Al.Anderson
  • 2,234 posts
  • Real Name:Al
Posted October 03 2012 - 02:43 AM
You stated it awkwardly, but yes - if you connect all devices the the receiver and then the receiver to the TV, it will work correctly.
The only exception is if you have an OTA antenna connected directly to your TV. Do you have that kind of connection?
#6 of 10 OFFLINE   Ider Gerelsuren
Ider Gerelsuren
  • 4 posts
Posted October 03 2012 - 07:09 PM
thanks. I dont think I have anything called Antenna.
#7 of 10 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,179 posts
  • Real Name:Robert
  • LocationMississippi
Posted October 04 2012 - 05:47 AM
If you aren't sure, then you don't have one. Antennas look like this - http://www.antennasdirect.com/ . I use one like this - http://www.antennasd...TV_Antenna.html in my attic to receive local HDTV channels.
#8 of 10 OFFLINE   Ider Gerelsuren
Ider Gerelsuren
  • 4 posts
Posted October 05 2012 - 09:40 PM
I dont have this, so I guess I would be fine.
http://www.onkyousa....ss=Receiver&p=f
I'm thinking about buying this AVR. Would it be able to connect my speakers, tv, and cable box via HDMI? just asking because it has 1 HDMI output slot
thanks..
#9 of 10 OFFLINE   Al.Anderson
Al.Anderson
  • 2,234 posts
  • Real Name:Al
Posted October 05 2012 - 11:23 PM
Yes, that receiver will do just fine. Unless you go high end, most receivers only have one HDMI output. What you need to be concerned with is how many inputs it has, and that model has plenty.
#10 of 10 OFFLINE   schan1269
schan1269
    HTF Expert
  • 14,931 posts
  • Real Name:Sam
Posted October 06 2012 - 06:08 AM
The X06 models are "prone" to HDMI board failure(last thought to have been as high as 9% failure the first year...) More than sure you are buying it used, since it is 4 years old. Make sure it works.
