Jump to content
Sanyo Z5 lamp problem - thermal reseting? Power supply?
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Rusakko
Rusakko
  • 2 posts
Posted September 16 2012 - 10:20 PM
Hi I have a Sanyo Z5 projector, which doesn't work anymore. I watched movie and suddenly the beam vanished and the lens cover closed itself. There flashed the "replace the lamp" and "power" leds. I have tried many times to put the projector on, but after lens cover has opened and fans are working I can hear some short time "electric buzzing" inside the machine and dim blue light can be seen from the lens. Then the projector shut down and led-lights start blinking... I have changed lamp with original one, but only the bulb, not the hole system. Total hours are maybe about 2200 hours with the projector. I opened the cover, pressed the thermal reset gentley. The button is weird. It's loose and it doesn't take up a position. It moves up and down, but pressing it doesn't result in any kind of "click" sound... ?! Maybe the button is broken? I also read some forums about broken power supply, but I'm not sure if it's possible with my diagnostics. Now, good advises would be very welcome! (and sorry about my language skills) Rusakko
#2 of 3 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted September 17 2012 - 02:05 PM
I don't know what it is, but you should post this in the Z5 thread at Avsforum.
#3 of 3 OFFLINE   Rusakko
Rusakko
  • 2 posts
Posted September 17 2012 - 07:55 PM
Ok, maybe I'll do that...:P
