Jump to content
Passive Subwoofer help
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   zero1234567888
zero1234567888
  • 1 posts
Posted September 09 2012 - 02:58 PM
Hello! I recently acquired a Harmon Kardon AVR325 receiver, and using some oldish speakers, I created a music 5.1 system. I have 2 JBLs as my main front and lefts, two Rock Solid Monitors and my left and rights, a bw vm6 as my center, and I am having trouble getting my Rock solid 100 watt passive sub woofer to turn on. I have ti wired through the jbls, but it doesn't seem to respond. Can anyone help, or recommend a good, cheap amp that I can connect from the sub to the rca port on the receiver? thanks
#2 of 4 OFFLINE   Al.Anderson
Al.Anderson
  • 2,301 posts
  • Real Name:Al
Posted September 09 2012 - 05:44 PM
You definitely need to amplify the signal, the HK uses a line level sub out and the passive speaker needs an amplified signal. I'm not up on sub amps, so I can't help with specifics, but someone will come along soon.
#3 of 4 OFFLINE   schan1269
schan1269
    HTF Expert
  • 15,679 posts
  • Real Name:Sam
Posted September 09 2012 - 08:01 PM
I moved the thread... Anyway, I would like to see how you've managed to run this off the JBL. Series? Parallel? But your best choice is to buy a mono amp. If you can handle used, Sony TA N110 is a good choice. They show up on Fleabay every once in a while. If you want new, here you go. There is also a similar amp sold by Dayton as well... http://www.amazon.co...ds=jamo mpa-101
#4 of 4 OFFLINE   av-holic
av-holic
  • 3 posts
Posted September 11 2012 - 01:14 PM
I have had good luck with the Crown product: Crown Commercial Audio Series, 180A It has 1 input and one 80W power amplifier for single-zone systems.
