Jump to content
Adobe Audition Adio Hardware setup problem
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   Kadebla
Kadebla
  • 9 posts
Posted September 01 2012 - 02:59 AM
Hello everyone, I have used Adobe Audition 3.0 for recording for some time now and I've never had any problems. However recently I had to uninstall my sound card driver( I use a Asus Xonar D1 Audio). After downloading it again I cant get Adobe to work. The problem is I cant get both speakers to play. When I go to the audio hardware setup in Adobe, I get this in the output box: Stereo: L,Ls,C,Lb or Mono:L,R,Ls,Rs,C,Sub,Lb,Rb I can only select one of the options and therefore only one speaker works. If I select L, then I only get sound from the left speaker, R-right speaker etc. Can anyone help?:confused: Thanks
#2 of 2 OFFLINE   Adam Gregorich
Adam Gregorich
    Executive Producer
  • 15,050 posts
  • LocationThe Other Washington
Posted September 01 2012 - 07:37 AM
Melkor, I don't have the answer, to your question, but I moved your post here to the PC/HTPC area where it stands a better chance of getting answered.
