Jump to content
Crossover settings to connect Bose sattelites directly to receiver?
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   NCRobino
NCRobino
  • 2 posts
Posted August 10 2012 - 10:28 AM
Hello! New here, so thanks in advance for the advice. Firstly let me start by saying I know the acoustimass speakers are not seen as the best choice out there and I get that. That said, I like them fine and would just appreciate the advice on what I have and not 10 reasons why I should sell them and get something else. That said, I'd like to add a rear center channel to my system. My Bose passive bass module only allows 5 speakers to be connected. Could I: 1. Set the crossover for all sattelites on my Pioneer receiver to protest casually protect the Bose sats from the low frequencies? If so, what should be the crossover settings I use? 2. If not, can I leave the 5 speakers connected through the bass module and add a new center channel or a Bose acoustimass center speaker somehow and connect it directly to the receiver safely? If I didn't get a Bose center speaker, what would be a good small speaker that would visually blend with the Bose aesthetic and sound well? Thanks for the advice!
#2 of 6 OFFLINE   NCRobino
NCRobino
  • 2 posts
Posted August 10 2012 - 10:30 AM
Ignore the Protest Casually words, not sure how that got in there!
#3 of 6 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,323 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted August 10 2012 - 10:55 AM
  This is about your only option.  Thankfully, since the rear center speaker is not used very frequently, there is little reason that it has to be a "match" to the rest of your speakers.  Small speakers like those from Energy or Mirage are options.  I can't offer any specific recommendation, however.  It's been a long time since I auditioned speakers.
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#4 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,290 posts
  • Real Name:Sam
Posted August 10 2012 - 10:57 AM
Well... You aren't supposed to set a crossover with the Acoustimass. About the only thing you could do is buy the VS100(I don't remember if that is an actual model number or not) center speaker, then use the Acoustimass XX(you don't mention which version) on everything NOT center. Also, in Pioneer you have 1 crossover, you'd have to choose small center, then large every other speaker.
#5 of 6 OFFLINE   Number1AVdork
Number1AVdork
  • 56 posts
Posted August 27 2012 - 10:12 AM
The cross over is built into the bass module...Bose is bad. Just ditch the bose. My 10$ Celestion bookshelf speakers put out twice the sound of the 5 speaker Bose v35 3000$ system. Can you really torture yourself much longer? The X-over is built into the module. Without connecting the cubes to module you will not get the speaker to work good and might even damage them. Good luck. Anything is better than Bose. I gave you one reason not ten :) I hope that helps. Seriously any modestly good lower end audiophile branded speaker will outdo the Bose. BOSE= BadOutscourcedSoundExperience
#6 of 6 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,290 posts
  • Real Name:Sam
Posted August 27 2012 - 10:29 AM
Bose... Pet name... Blose "Sales jargon"...er anti-sales jargon... "No highs, no lows...must be B(l)ose"
