Jump to content
Need some help with a mixed stereo system
1 reply to this topic
#1 of 2 OFFLINE   pyniefresh98
  • 1 posts
Posted August 08 2012 - 01:50 PM
I have a Technics SA-GX170 stereo receiver, a Wharfedale Sub Bass 2130 sub woofer and a Sony HCD-RG20 CD player as well as various speakers that hook up with stereo wire. My old roommate left most of it when he moved out and I was wondering if there was any way to get it all to work off of eachother, as well as what i would need to do it.
#2 of 2 OFFLINE
  • 0 posts
Posted August 08 2012 - 05:07 PM
It should all work together.  Below is a picture of the back of the Technics SA-GX170
Posted Image]
I don't know exactly how the Technics receiver will work with two sets of speakers, but it appears that you can hook up to sets of speakers to the speaker connectors on the back of the Technics.  Make sure that you put the copper color part of the speaker wire in the red connector for both the Technics and the speaker and the silver part in the black for both the speaker and the Technics.
I can't find the layout of your subwoofer, but since your receiver doesn't have any outputs except for speaker outputs, you would take speaker wire from the Technics and plug it into the back of your sub.  Some subs have output that you then would plug your speakers into as the sub would have a crossover that would just have the low frequenies go to it and then pass the higher frequencies to your speakers.  However, I can't determine that as I can't see any manuals or pictures for the sub.
Hope that helps.
