Jump to content
DLP vs. LED
  • Please log in to reply
14 replies to this topic
#1 of 15 OFFLINE   Tom-G
Tom-G
  • 1,646 posts
Posted July 15 2012 - 10:03 AM
Been getting the upgrade bug recently. I currently have a 52" DLP. I've had my eyes on a 60" LED (Sharp Aquos) but also have been kicking around the idea of sticking with DLP. I am doing research on each technology and was hoping members here would be kind enough to weigh in with their opinions. So -- given the choice, which technology would you go with and why? Thanks for the input.
#2 of 15 OFFLINE   Steve Tannehill
Steve Tannehill
    Producer
  • 5,550 posts
  • Real Name:Steve Tannehill
  • LocationDFW
Posted July 15 2012 - 10:39 AM
DLP is the best bang for the buck.
#3 of 15 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,021 posts
  • Real Name:Sam
Posted July 15 2012 - 11:32 AM
If I'm correct....(which at the beginning of the "year" I was, but "clearance time" is coming)... You can buy the top 82" DLP(there are two versions) and it still costs less than the cheapest Sharp Aquos 60". Once you hit 60"... In sales... 1. Plasma 2. DLP(and there is only Mits) 3. LCD
#4 of 15 OFFLINE   Ed Moxley
Ed Moxley
  • 2,701 posts
  • Real Name:Ed
  • LocationEastern NC
Posted July 15 2012 - 06:23 PM
I prefer DLP. You get bigger screen for your money. You get a screen that doesn't reflect. The picture on a DLP looks more film-like, whereas the picture on plasmas, LCDs, and LEDs looks more like video. You may have to replace the bulb in a DLP every 3-4 years, but when you do, it looks like a new tv.. I don't want to hang my tv on the wall. Afterall, it's a tv, and not a picture. Good luck with whatever you decide on.
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
SVS PC12-NSD (Sub)                       ...
#5 of 15
Posted July 15 2012 - 08:35 PM
Keep in mind that there are less manufacturer choices between flat panel and DLP.  Mitsubishi is one of the last big names out there.  If space (i.e. depth) is a critical factor than DLP is going to be more of an issue than flat panels.  I also haven't seen a DLP that is wall mountable.
However, the previous posts are correct that DLP, particularly when going to large screen sizes is cheaper.  In some cases it's hard to find a flat panel HDTV that comes close in size to some of the larger DLP RPTV's.  For instance Mitsu's 92" DLP RPTV!
DLP also has other advantages, the biggest one is the viewing angle, particularly going up against LCD based flat panel displays.
Not all flat panel displays have a glossy coating so depending on the model of the flat panel, reflections might not be that big of an issue.  However, the best viewing is in a light controlled environment and even a non-gloss surface still shows light.
In terms of performance, you need to make sure the DLP RPTV that you are looking at supports native 1080P, including support for 24FPS material.  Some of the older one's only supported wobulation, which never provided true 1080P support and they didn't support 24FPS. Most name brand flat panel displays support 24FPS.
I saw the Mitsubishi at CEDIA last fall and it looked pretty nice.  I have never been able to get Mitsubishi to supply us with a review unit so I could evaluate it with test patterns.
I have an older Toshiba DLP RPTV and it is great for a living room display.  The problems with that DLP was that it used wobulation, didn't support 24FPS and didn't support dot by dot resolution.
The top end Mitsubishi, the http://www.mitsubish...=1&a=B007TGKLFM
The other 92" option is the http://www.amazon.co...=1&a=B004ZL2O9U
Now trying to find one of these locally?!  Good luck.  In my area there is only one retailer that sells them and I don't know if they sell the units I am referencing above.  On Amazon you get free shipping...
#6 of 15 OFFLINE   Robert Crawford
  • 26,023 posts
  • Real Name:Robert
  • LocationMichigan
Posted July 16 2012 - 06:09 AM
If you have an ABC Warehouse store in your area, they sell Mitsubishi DLPs.
Blu-ray Preorder Listing
#7 of 15 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,021 posts
  • Real Name:Sam
Posted July 16 2012 - 08:19 AM
HH Gregg sells them, and it looks like Pittsburgh has a couple of them.
#8 of 15 OFFLINE   Peter McM
Peter McM
  • 930 posts
Posted December 01 2012 - 05:18 AM
Got my 60" Mitsubishi two years ago. As long as DLP continues to be available, that will always be my choice.
I am Car Salesman of Borg. You will be assimilated with no money down and easy terms available.
#9 of 15 OFFLINE   Mr645
Mr645
  • 215 posts
  • Real Name:Jon
  • LocationBoca Raton, Florida
Posted December 01 2012 - 06:55 AM
Can't complain about my Samsung 67" DLP. Very sharp, nice picture. The newer sets do look nicer, but not $2000 nicer and I would totally consider a 73" Mitsu DLP f I needed a new TV . especially with the $799 price tag. 82" may be a bit big for my space
#10 of 15 OFFLINE   Radioman970
Radioman970
    Producer
  • 6,409 posts
  • Real Name:James Perry
  • LocationCould be anywhere
Posted December 01 2012 - 08:59 AM
How does the 60, 120, 240 etc... come into it on the DLP, LED and LCD? I'm very picky about smooth running video. I returned a 60hz Samsung LCD and a 120hz Vizio LCD since neither worked correctly with a Panny BD HTiB. Jerky video. I believe the problem was probably the HTiB all along. But a Panny Plasma TV was the 3rd try and the charm. I know it's not an issue with Plasmas... I'd also be interested in knowing if there is any differences in 3D performance across those technologies.
Silly Party Candidate: Tarquin Fin- tim- lim- bim- whin- bim- lim- bus- stop- F'tang- F'tang- Olè- Biscuitbarrel
#11 of 15 OFFLINE   schan1269
schan1269
    HTF Expert
  • 16,021 posts
  • Real Name:Sam
Posted December 01 2012 - 09:15 AM
First(and for the, what, fifth time just today???) there is no LED and LCD.... There is LCD with CCFL or LED backlight. Period. LCD have a native refresh of 60hz. Artificial refreshing was created at 120, 240, 480 and "faster"(known as CMR rates with Samstung...by the way Samstung is the cause of this "LED confusion") Samstung spelled that way on purpose. 120hz is the refresh rate DLP needs for smooth motion. It doesn't need to get any quicker. LCD needs "math" to create a clear picture...as LCD was never created to produce a moving picture. The issue is(and yeah, I only own LCD at sizes where there was no other choice) once you get beyond 120hz in LCD...it starts looking "fake". There is nothing you can do about it.
#12 of 15 OFFLINE   Radioman970
Radioman970
    Producer
  • 6,409 posts
Posted December 01 2012 - 11:50 AM
Thanks. I didn't know. You made my shopping easier. Here, for you....
#13 of 15 OFFLINE   TonyD
TonyD
    Who do we think I am?
  • 16,554 posts
  • Real Name:Tony D.
  • LocationDisney World and Universal Florida
Posted December 01 2012 - 05:34 PM
I've had my Mits 73" for a tad over six years now. While I love the size and there is a very good chance th next one will also be dlp, my main issue is the number of times I had to replace the light engine. Since I haven't done any research lately I'm not even sure that comes into play anymore. After four years I was already on my third light engine so it was replaced twice. Anyway I need big so next one will be 82" at least so for cost I might not be able to afford LED at that size.
facebook.com/whotony
#14 of 15 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,721 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted December 01 2012 - 09:48 PM
Do these 73" and larger Mits. DLP's have wheels like their RPTV's used to? Or are they meant to be put on a stand?
#15 of 15 OFFLINE   TonyD
TonyD
  • 16,554 posts
  • Real Name:Tony D.
Posted December 01 2012 - 09:53 PM
dlp is a rear projection but I think you mean crt. No wheels they go on a stand.
