Jump to content
What cables am I going to need
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   allendehl
allendehl
    Extra
  • 20 posts
Posted June 11 2012 - 07:04 AM
Hi guys, With your help I ordered a Denon AVR1712 and an Onkyo SKS-HT540 7.1 speaker system. I've heard that the cables that come with them are usually very cheap and is a good idea to replace them. Can anyone tell me what is that I will need so I can order them without having to wait for the receiver and the speakers to be delivered? Thanks a lot!
#2 of 2 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,210 posts
  • Real Name:Robert
  • LocationMississippi
Posted June 11 2012 - 07:20 AM
Why don't you connect it with the included cables and see if they work OK. Speaker wire is speaker wire. A heaver gauge will have slightly less resistance but will not improve the sound. If the included sub cable doesn't pick up any interference then it is fine. But if you want new speaker wire and/or a new sub cable, then Monoprice.com is the place to start.
