Bill Santagata
- Jun 1, 2012
- Bill Santagata
I just bought a Blu-ray player (Sony BDP-S185) although I do not yet have an HD TV (I'm sure I"ll be getting one soon and in the meantime want to be able to stop buying DVDs).
It's hooked up to a standard ratio television and when I play a movie originally shot in Academy ratio, the image does not fill the screen as it should but has black bars on the top and bottom to create a widescreen TV ratio, then black bars on the left and right to create the Academy ratio.
By fiddling with the settings I can only get rid of the bars on the top and bottom but the image is stretched vertically.
How can I get the disc to play normally?
Thanks for your help.
