-Not Logged In-
Jump to content
Mitsubishi HC-4900 LCD Projector projects greenish color !
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   chimmoi
  • 1 posts
Posted May 26 2012 - 10:59 AM
Hi all, I would like to get some advice of what the problem might be on my projector: I have a Mitsubishi HC4900 1080p projector that works great for me until now. It only has 600 hours on it. Suddenly, when my son was playing on the X-box, everything froze. Ever since then, the projector only projects greenish color on the screen. I disconnected all cables from the projector, it still projects greenish color. I switched from HDMI to DVI, Components,... to no avail. Can anyone suggest what might have gone wrong with my projector ? Some said one of the LCD filters has gone bad. Some said it's the mainboard. Some said it's the LCD block. I need some advice of how to go about further troubleshooting it. Is it worth repairing ? This project is 4 years old and worked great for us. It has native resolution of 1920 x 1xxxx which I love. Thanks in advance.
#2 of 2 OFFLINE   Jim Mcc
Jim Mcc
  • 3,744 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted May 26 2012 - 07:05 PM
This doesn't sound good. I would hook up another component to it and see what happens(Blu-ray player, DVD player,etc.). And again, check all the different inputs of projector and player. If that doesn't work, I would try different cables.
