Jump to content
Need a little advice - outdoor speakers with Yamaha receiver
2 replies to this topic
#1 of 3 OFFLINE   jslow68
jslow68
  • 6 posts
Posted May 22 2012 - 01:51 AM
I have been banging my head against the wall trying to get my outdoor speakers to work. I have a 5.1 system inside. I purchased a Yamaha RX-V671 receiver with a 2nd zone to run the outdoor speakers. I wanted to run my outdoor speakers off this but I found out they will only take an analog signal. I am trying to access my music through apple tv. But that is hooked up with and HDMI cable, so it won't work. I also tried a external 2 channel amp connected to the Zone 2 out jacks. Still nothing. Does any one have a solution? Whats the point of the second zone if it's only analog? I'm not an expert by any means. So any help is appreciated. Thanks!
#2 of 3 OFFLINE   Adam Gregorich
Adam Gregorich
    Executive Producer
  • 14,916 posts
  • LocationThe Other Washington
Posted May 22 2012 - 03:24 AM
Thanks!
Some of the higher end models allow both digital and analog switching for zone2.  Its not the amp its the actual switching in the receiver.  You either need to just plug in a CD player that can playback MP3 burned CDs, a portable MP3 player like an iPod/iPad, or if you want to use your Apple TV get a D to A converter and in addition to the HDMI input plug it into an analog input for your zone 2 speakers.  Something like this:
http://static.hometh...um.com/imgrepo/
Its about $30 with shipping from Amazon.  You would take the included cable, plug it into the Toslink output on your Apple TV (I am assuming you have the current version) and then connect the analog output from the converter to your receiver.
#3 of 3 OFFLINE   jslow68
jslow68
  • 6 posts
Posted May 22 2012 - 05:37 AM
Thanks a lot for your help! I appreciate it.
