Jump to content
Cleaning an LCD computer monitor
7 replies to this topic
#1 of 8 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted April 08 2012 - 02:48 PM
What do you guys recommend I use? Does the power need to be unplugged first? Thanks.
#2 of 8 OFFLINE   Stan
Stan
  • 2,179 posts
Posted April 09 2012 - 05:31 AM
I was diabetic for several years so have loads of those little isopropyl alcohol pads used to clean your injection site. One day I used one to clean my LCD computer screen and it worked great. Have used them for years now to clean the screen, keyboard, touchpad, and just about everything else. Never had a problem. They're small so probably not a good solution for a widescreen tv, but for a computer they work great. Don't think I ever even turned the power off, but looking back it probably would be a good idea. What's nice is that you're not spraying anything, it's all soaked into a little pad so no excess overspray to clog up the keyboard, or anything else. Might not be the recommended cleaning solution, but as I said, I've done it for years without a problem.
Stan
#3 of 8 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
Posted April 09 2012 - 08:50 AM
Thanks Stan. I was looking online and I found out what's recommended were 2 things. 1) Either a 50/50 mix of distilled water and rubbing alcohol or 2) A 50/50 mix of distilled water and white vinegar. And both said to use a clean microfiber cloth, and spray onto the cloth. NOT to spray directly on the screen. Also they said to unplug the minitor first.
#4 of 8 OFFLINE   Stan
Stan
  • 2,179 posts
Posted April 12 2012 - 03:24 AM
Thanks for the info Jim. I should switch and start doing things properly. Amazing about white vinegar. My grandmother recommended it for a cleaning a lot of things and that was probably 30 years ago. It's nice to know certain things never go out of style.
Stan
#5 of 8 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
Posted April 12 2012 - 04:36 AM
I cleaned it with the 50/50 distilled water and rubbing alcohol mix and it worked great. This is what I use for DVD's also.
#6 of 8 OFFLINE   LiuLucy
LiuLucy
  • 2 posts
Posted April 27 2012 - 09:06 PM
I would prefer to clean it from nail remover. Natural skin care products
#7 of 8 OFFLINE   Gregg Loewen
Gregg Loewen
    Producer
  • 6,326 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted May 11 2012 - 12:59 AM
Monster screen cleaner works great (with a microfiber cloth).
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
#8 of 8 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
Posted May 11 2012 - 06:08 AM
Thanks, but I refuse to buy anything sold by Monster.
