Jump to content
15" "car" subwoofer in home using Onkyo 5.1?????? HELP!!!!
3 replies to this topic
#1 of 4 OFFLINE   jdmjosh
jdmjosh
  • 1 posts
Posted March 08 2012 - 05:36 AM
Just curious if i hook up my 15" sub from my car to my Onkyo 5.1 receiver if it will work??? Do i just run an RCA from the Sub-Out on the receiver to the sub, then at the sub cut the rca connector and wire the + and - wires accordingly to the sub???? is it that simple??? thanks
#2 of 4 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,160 posts
  • Real Name:Robert
  • LocationMississippi
Posted March 08 2012 - 06:20 AM
No. Your "car" sub is passive. You need an amp between the LFE (subwoofer) output of your Onkyo and the sub. After you add an amp, it may work. What impedance is your sub? What kind of enclosure? If ported, what is the tuning frequency? What driver are you using?
#3 of 4 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted March 08 2012 - 08:32 AM
You're better off selling the car sub and buying a powered home sub.
#4 of 4 OFFLINE   Mr645
Mr645
  • 213 posts
  • Real Name:Jon
  • LocationBoca Raton, Florida
Posted March 08 2012 - 02:08 PM
Send the LFE RCA cable to an ampliflier, ideally one designed for powering a sub. The car sub in a proper enclosure will probably work pretty well. Make sure the amp you buy can deal with whatever ohm rating the speaker is.
