Jump to content
Pioneer 1021 Wireless Question...
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   derrell*
derrell*
  • 7 posts
Posted February 22 2012 - 11:36 AM
Hello. Can you use wireless speakers with this Pioneer 1021 receiver? If so, is there anything that needs to be done or added to in order for the wireless speakers to work? Thanks...
#2 of 12 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,566 posts
  • Real Name:John
  • LocationNorCal
Posted February 23 2012 - 04:30 AM
Wireless speakers should work with any receiver or source than can connect to them, so the answer is: it depends on the speakers, not the receiver.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#3 of 12 OFFLINE   derrell*
derrell*
  • 7 posts
Posted February 23 2012 - 07:54 AM
Thanks for the info. I'm planning on using only wireless for the 2 rear speakers. So, I guess what you are saying is that I don't need any special adapter, and that the 2 rear speakers will play automatically? Again, thanks...
#4 of 12 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,163 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted February 23 2012 - 08:28 AM
Derrell, are you setting up a 5.1 or 7.1 system?  If 5.1 you should know that the "surround" speakers really ought to be placed to the sides of the listening position, not behind (see these placement guidelines from Dolby).
Of course, room geometry frequently trumps placement guidelines, but just thought you should know.
Which wireless system are you considering?  Do you already have it?  Are you aware that most "wireless" systems still require the speakers be connected to the wireless receiver unit with regular speaker wire and the wireless receiver unit will need to be plugged into a wall outlet for power?
You may already know these things, but we often get a lot of inquiries about "wireless" systems from folks who think they truly are completely wireless and have no idea how they actually work.
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#5 of 12 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,566 posts
  • Real Name:John
  • LocationNorCal
Posted February 23 2012 - 08:42 AM
Derrell, are you setting up a 5.1 or 7.1 system?  If 5.1 you should know that the "surround" speakers really ought to be placed to the sides of the listening position, not behind (see these placement guidelines from Dolby). Of course, room geometry frequently trumps placement guidelines, but just thought you should know.
Dolby is also generally recommending bi/dipole surrounds, so side mounting does not necessarily apply for monopoles, which are the only type of wireless powered speakers you are likely to find (aside from buying a wireless system, amp, and speakers yourself). Bi/dipoles can also be mounted behind, it just requires more careful placement and calibration. I personally prefer monopoles, and I have a 5.1 setup with monopoles to the sides and behind, and it works perfectly. Their guidelines show the rears pointed at the listener. I do not recommend this, they should be pointing more toward the center of the room, but not right to your ears. It gives good directionality while not being "in your ear".
Which wireless system are you considering?  Do you already have it?  Are you aware that most "wireless" systems still require the speakers be connected to the wireless receiver unit with regular speaker wire and the wireless receiver unit will need to be plugged into a wall outlet for power? You may already know these things, but we often get a lot of inquiries about "wireless" systems from folks who think they truly are completely wireless and have no idea how they actually work.
Agreed. At the very least, you will still have one wire that goes between the two speakers. The speakers should come with the transmitter and either have the receiver built in or included, and yes, they will need to be plugged in.
#6 of 12 OFFLINE   derrell*
derrell*
  • 7 posts
Posted February 23 2012 - 04:04 PM
This will be a 7.1. I do not have any speakers yet. Any suggestions on which speakers to buy?
#7 of 12 OFFLINE   derrell*
derrell*
  • 7 posts
Posted February 27 2012 - 11:01 PM
Still curious which speakers to purchase. Any suggestions would be appreciated. Thanks...
#8 of 12 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,163 posts
Posted February 28 2012 - 01:05 AM
I know RocketFish makes this wireless "kit" that consists of the wireless transmitter that gets plugged into your receiver, and the receiver unit which plugs into the back wall, and receives the signal from the front of the room.
I verified the product documentation (here) and it should work with your system - it connects using the regular speaker wire connections at both ends.
A kit like this allows you to use whatever speakers you may already have as the back surrounds.  While I don't have any direct experience with this sort of system, I like this approach in that you don't have to compromise the quality of the speakers.
A quick look at systems that included speakers all seemed to include pretty low-end speakers.  Granted, for rear surrounds in a 7.1 system, you don't really need to "match" the speakers to the rest in the system, but if you can find a good package deal on a 7.1 speaker set, you may be better off.
If you give us an idea of budget, we can probably offer additional speaker options.
#9 of 12 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,566 posts
  • Real Name:John
  • LocationNorCal
Posted February 28 2012 - 03:33 AM
http://audioengineus...ioengine-5-Plus http://www.aperionau...Systems,88.aspx
#10 of 12 OFFLINE   derrell*
derrell*
  • 7 posts
Posted March 04 2012 - 09:08 AM
I've taken all that's been said into consideration and have researched items suggested. I came across this set. What do ya'll think? The room size I'll have it in is 20x25. Thanks... http://www.crutchfie...1600 5.1&tp=184
#11 of 12 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,163 posts
Posted March 05 2012 - 01:25 AM
Polk makes some decent speakers, but for a room that size, the 8" subwoofer, IMO, is inadequate.  Generally, I'm not a fan of picking up speaker "systems" that include a subwoofer, because most speaker manufacturers don't make very good subwoofers.
Bought separately, you can get the 4 satellites and matching center for about $420.
For $130 you can get this 12" Dayton sub which would be a marked improvement.
For about $50 more, you can also opt for the Bic F-12 which is arguably one of the best performers under $200.
The most important thing is to try and listen to speakers before you get them.  I know that's not always possible, but there's only so much specs alone can tell you (subwoofers aside - specs are much more meaningful for them).
#12 of 12 OFFLINE   derrell*
derrell*
  • 7 posts
Posted March 05 2012 - 05:08 AM
Interesting. I see your point. I checked out the Dayton speaker and looks good. You mentioned 4 satellites and matching center: What brand do you recommend for my size room. At this time, I'm not going to get wireless rear speakers as was discussed earlier. That will come later. Again, thanks...
