staceybassoon
- Feb 13, 2012
- Stacey Jamison
Help me, wise home theater guru's, you're my only hope! So I got a Roku box last week. It has two options for output - RCA and HDMI. Both cannot run at the same time. The RCA works fine, but obviously I want to use the HDMI (which is why I got the model I did). As you may know about this particular receiver, it only does HDMI pass-through, and not full HDMI. I didn't realize this until trying to get this all to work for the last week. We already have one of the HDMI ports being used by our BluRay player, accompanied by the optical line. The second HDMI port, and the available one calls for an HDMI cable and a COAX. Well, the Roku doesn't have a COAX option for audio. Is there anything I can do to set-up the HDMI to work anyway? Some mysterious solution in the way of a cord, converter, or fancy footwork that I don't know about? My back-up solution doesn't work either. I was just going to plug it directly into the 1 HDMI port on my TV, which is how the receiver is hooked up for BluRay. I did that, I get a picture but NO AUDIO. I have talked to two Sony techs and one Roku tech, none of whom could help me. The Sony techs are useless. Does anybody have any ideas? I'm just not ok with this not working... Thanks! Stacey
