Jump to content
Reputable dealers for front projector replacement bulbs?
3 replies to this topic
#1 of 4 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,019 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted January 04 2012 - 02:29 AM
So after several years of regular use, I got the first "warning" from my Mitsubishi HD1000U projector that the bulb/lamp is nearing the end of its life.
I got the projector from the fine folks at ProjectorPeople.com and will strongly consider getting my replacement lamp from them as well.
As I've read in several places before, there are generally two "tiers" of pricing for replacement lamp assemblies - the more expensive is usually OEM while the cheaper lamp a knockoff brand/OEM "equivalent".
In terms of price difference, we're talking $300-350 vs. $100-150.
I'm not in the market for a new projector - it will be a replacement lamp.  I'm perfectly willing to pay the higher price if it's truly a safer bet, and I'll get a higher quality lamp that will last another couple thousand hours of regular use.
Does anyone have any experience with various retailers out there for replacement lamps?
Some of the retailers that offer the lamp at the higher price include:
ProjectorPeople (I know these folks are the real deal)
TigerDirect
B&H Photo
Any thoughts/experiences with these retailers?  Any others?
Thanks for any input.
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#2 of 4 OFFLINE   Gregg Loewen
Gregg Loewen
    Producer
  • 6,342 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted January 04 2012 - 09:42 AM
My retail price is $275. I would never buy a non OEM bulb for a projector. What happens if the bulb fails / explodes ?
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
#3 of 4 OFFLINE   Steve Berger
Steve Berger
  • 962 posts
Posted January 05 2012 - 12:39 AM
Some projectors tolerate generic bulbs better than others. I would only even remotely suggest an aftermarket lamp if you have a local storefront to "walk" it back into if it fails to work properly. If you order online, do it from Mitsubishi and not some retailer, unless you can verify that they supply "Factory" lamps. (ie Authorized Mitsubishi Distributor) Otherwise you could end up with a generic lamp without realizing it. (at full Factory price)
#4 of 4 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,019 posts
Posted January 05 2012 - 01:14 AM
Thanks for the input.  I'll play it safe and stick with the people I know - ProjectorPeople.  They were fantastic when I got the projector in the first place.  The first projector they sent actually died after running for only 10 minutes.  They immediately sent a replacement as well as a prepaid packing slip for me to return the faulty model directly to Mitsubishi.  Their tech support staff were friendly and very helpful, and followed up to make sure all was fine.
I know they only offer OEM bulbs and are a Mitsubishi authorized dealer.
