Jump to content
Question about Samsung wireless rear speakers, SWA 5000
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   keatonxj7
keatonxj7
  • 3 posts
Posted January 01 2012 - 08:53 AM
I have the Samsung HT D5300 and wanna run my rear speakers wirelessly, since i don't like the wires running under the carpet and up the wall. I found the Samsung SWA-5000. Im wondering if its compatible? Anyone here have it? I found it online for $99 for the rear transmitter and receiver module kit. HTIB: http://www.crutchfie...tml#details-tab Wireless Receiver: http://www.abt.com/p...ampaign=froogle
#2 of 3 OFFLINE   David Willow
David Willow
    Babbling Idiot
  • 2,208 posts
  • Real Name:Dave
  • LocationMechanicsburg, PA
Posted January 01 2012 - 11:19 AM
Wireless speakers generally do not work well. Plus, you will still have wires - you have to plug them into an outlet. One thing to consider is your speaker placement. The surrounds should go on either side of the listener, not behind (no rear). Maybe placing them on the sides would make it easier for you to install.?.? Dolby Speaker Placement Guide
I’m training to run a marathon for the Leukemia & Lymphoma Society, to raise life-saving funds to help those fighting blood cancers. Please help! See details and donation link here.
Dolby and DTS Plaques (downloads)
Audyssey Setup Guide
#3 of 3 OFFLINE   Joseph DeMartino
Joseph DeMartino
    Lead Actor
  • 8,308 posts
  • Real Name:Joseph DeMartino
  • LocationFlorida
Posted January 01 2012 - 11:56 AM
According to the specs on the Crutchfield page, your HTiB does have a TX card slot that will allow you to connect the SWA-500 to it.
Optional Wireless Receiver Module: To connect the system's surround speaker wirelessly, you can purchase the Samsung wireless receiver module and TX card (SWA-5000, sold separately).
Understand that the "wireless" rear speakers are never actually wireless. The receiver/amp needs a power connection, and you need to run wires from it to each surround speaker. All you're really saving is the wire run from the front of the room to the back. (And that's often an exaggerated concern. I have wood laminate flooring in my living room. I use a simple white plastic channel running along one wall from my home entertainment unit to behind my couch. The wires for my surround speakers, which are on low stands on the end table either side of my sofa, are easily hidden. The plastic channel is virtually invisible. appearing to be part of the molding.) Hope this helps, Joe
