Jump to content
HDMI Signal Problem - Help !!!!!!
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   jjw white66
jjw white66
  • 1 posts
Posted January 01 2012 - 04:59 AM
Just purchased a Yamaha RXV571, 7.1 Receiver. Hooked it to new 42" LG LCD. I hooked up an HDMI cable from the HD cable Box to the Receiver and a HDMI cable from the Receiver to the TV. Problem is when I change channels, there is a delay anywhere from 15- 45 seconds before the picture shows up and the sounds cuts in and out. Other than that all appears good, but very annoying. Anyone have any ideas what I can do to fix ???? Thanks,
#2 of 5 OFFLINE   gene c
gene c
    Producer
  • 5,804 posts
  • Real Name:Gene
  • LocationBay area, Ca
Posted January 01 2012 - 07:39 AM
Sounds like the receiver is having trouble locking on to the signals. Try doing a Factory Reset on the 571. The procedure should be listed somewhere in the manual. If you do, it will revert all settings back to the factory default settings. If a reset procedure isn't available try un-plugging the receiver for 30 min. This probably won't help any but it's easy to do :blush: To narrow the problem down to the receiver try plugging the cable box directly into the display just to see what happens. You could also have a bad hdmi cable(s) but I'm not sure if a bad cable would cause your problem.
"Everyday room": Panasonic 58" Plasma, Dish HD DVR, Pioneer Elite vsx-23, BDP-23 BR, dv58avi universal dvd player, Paradigm Studio 20 V1, CC-450, Dayton HSU-10 subwoofer.
"Movie/Music room": Toshiba 65" DLP, Dish HD receiver, Marantz 7005, CC-4003, BD-7006, Polk LSI25's-LSi7's-LSiC, 2 original Dayton 10" "Mighty-Mites" subwoofers. (subject to change without notice).
Also have  MB Quart Vera VS05 +.....too much to list. Help me.
#3 of 5 OFFLINE   govtdog
govtdog
  • 6 posts
Posted January 02 2012 - 03:11 AM
I've found that sometimes the HDMI handshake doesn't go very well and alot depends on the HDTV in some cases. It gets even more complicated if you first run the HDMI signal through your receiver prior to forwarding it to your HDTV. Occasionally, I have to reach around the HDTV and unplug and then replug the HDMI connection to the HDTV too. :( If I were you and had this option, I'd probably connect the HDMI directly from the TV signal source(cable or satellite) and then also run a seperate connection to my audio setup... even if that means an analog L/R audio connection to my TV.
#4 of 5 ONLINE   Ronald Epstein
    Studio Mogul
  • 43,239 posts
Posted January 02 2012 - 03:58 AM
Jeff, Welcome to our forum.  Hope you stick around and talk about your new receiver, display and the movies you watch with them. Good advice given here thus far. HDMI handshaking can be rather complicated at times. Even when I switch inputs on my equipment, I get seconds of interruption as the equipment syncs with each other.  Your predicament sounds fairly worse than what others usually experience.
Ronald J Epstein
Home Theater Forum co-owner
 Click Here for the latest/hottest Blu-ray Preorders  Click Here for our complete Blu-ray review archive
 Click Here for our complete 3D Blu-ray review archive Click Here for our complete DVD review archive
 Click Here for Blu-Ray Preorder Release Schedule  Click Here for forum posting rules and regulations
#5 of 5 OFFLINE   Brian McHale
Brian McHale
  • 514 posts
  • Real Name:Brian McHale
Posted January 03 2012 - 05:46 AM
Sounds like you need to change a setting on your cable box. Usually, there's some settings that allows you to choose 1080i, 720p, etc. One of these choices is something like "source", which means the box will change what it's outputting depending on the source material, which can change from 1080i to 720p to 480i as you change channels. The reason you might want to use this setting is that your TV (or outboard video processor) might do a better job of upconverting than your cable box. The downside is that it will take a while for your other gear (TV, AVR, etc.) to adjust. If you set your cable box to output either 720p or 1080i all the time, I suspect your problem will go away.
Brian
