Jump to content
Crossover Settings for Klipsch F-30 System
1 reply to this topic
#1 of 2 OFFLINE   rikinky17
rikinky17
  • 3 posts
Posted December 08 2011 - 03:00 AM
I was wondering if anyone can help me with the crossover settings for this system? It is Klispch F-30 System. Here is the spec for each speaker. I have a Denon reciever that allows me to adjust each crossover setting individually as well. Klipsch F-30 System Fronts http://www.klipsch.c...tanding-speaker Center http://www.klipsch.c...-center-speaker Surrounds:http://www.klipsch.com/s-20-surround-speakers-pair Sub:http://www.klipsch.com/sw-450-subwoofer Receiver Denon AVR-791 OK the question I have is can I set the fronts to Large on this system and what is your recommended crossover setting for each speaker and what do I set the sub crossover to? I have heard you should never set the fronts to Large and etc and wanted to see what everyone else thought. Right now I have the crossover set to 60hz and the sub to 80 Hz and Fronts to Large and everything else to small. Should I individually set each speakers crossover or just flat setting? Thanks for all the help.
#2 of 2 OFFLINE   gene c
gene c
    Producer
  • 5,720 posts
  • Real Name:Gene
  • LocationBay area, Ca
Posted December 08 2011 - 11:09 AM
I'd set all speakers to Small, the crossover on the center and surrounds to no higher than 100 and 120 might be better. They only go down to 82-83hz anyway. The fronts to no lower than 60 with 80 probably better. Send all those really deep notes to the sub. It's designed to handle them.
"Everyday room": Panasonic 58" Plasma, Dish HD DVR, Pioneer Elite vsx-23, BDP-23 BR, dv58avi universal dvd player, Paradigm Studio 20 V1, CC-450, Dayton HSU-10 subwoofer.
"Movie/Music room": Toshiba 65" DLP, Dish HD receiver, Marantz 7005, CC-4003, BD-7006, Polk LSI25's-LSi7's-LSiC, 2 original Dayton 10" "Mighty-Mites" subwoofers. (subject to change without notice).
Also have  MB Quart Vera VS05 +.....too much to list. Help me.
