Jump to content
Sign up for a free account!
rattling sound from one front speaker
  • Please log in to reply
3 replies to this topic
#1 of 4 brankulo
brankulo
  • 28 posts
Posted October 06 2011 - 10:16 AM
one of my front speakers is producing rattling sound at certain low frequency. i know it comes from speaker as i switched front speakers and now it comes from other direction. any idea what might be wrong? thanks
#2 of 4 Robert_J
Robert_J
    Lead Actor
  • 8,051 posts
  • Real Name:Robert
  • LocationMississippi
Posted October 06 2011 - 01:58 PM
Driver coming loose from the enclosure. Dust cap coming loose from the cone. Surround torn or wearing out. What did you see when you took a closer look? What speaker is it? This is like writing in to a car magazine and saying "My vehicle is making a 'ka-chunk' sound. What is wrong?" There needs to be some back and forth to dig deeper.
#3 of 4 brankulo
brankulo
  • 28 posts
Posted October 07 2011 - 02:23 AM
i havent inspected the speaker yet, did check for loose cables but they are good. will check what you suggesting today and post outcome. it is definitive tech pro cinema 1000 speaker. 10 months old. dont use it too often, maybe twice a week for a movie length, not cranking it much either.
#4 of 4 brankulo
brankulo
  • 28 posts
Posted December 29 2011 - 10:11 AM
so i took the speaker apart, and found out that 2 plastic housing that front cover screws into are cracked, screw wouldnt screw tight, i could just spin it forever, like if the thread was gone, which is probably what happened. so i am assuming that front cover was causing rattle. i repaired housings using jb weld, put a dab into thread holes. after it was dry screws went in tight. will still have to test it.
