Jump to content
Compatibility issue - Samsung 3D TV with Panasonic 3D Blu-ray player
5 replies to this topic
#1 of 6 Imty
Imty
  • 3 posts
Posted September 10 2011 - 09:25 PM
Hi, I'm intending to buy a Samsung UA55D6400 3D LED TV and Panasonic DMP-BDT300 3D Blu-ray player. Will the two be compatible? The reason for my choosing the Panasonic player is because it has 2 HDMI outputs which helps me retain my legacy Onkyo AV Receiver. Would appreciate all the help on this. Thanks.
#2 of 6 Matt Hough
    Executive Producer
  • 11,022 posts
  • LocationCharlotte, NC
Posted September 11 2011 - 12:24 AM
Completely compatible.
#3 of 6 Imty
Imty
  • 3 posts
Posted September 11 2011 - 01:37 AM
Thank you Matt. If I wanted to know how these are compatible would it be too much ask of you? Appreciate your help.
#4 of 6 Adam Gregorich
Adam Gregorich
    Executive Producer
  • 14,741 posts
  • LocationThe Other Washington
Posted September 11 2011 - 03:47 AM
Originally Posted by Imty
Thank you Matt.
I'm not sure what you mean.  They both meet the 3D Blu-ray specifications so they are compatible.  The only compatibility issues that exist around three 3D are with the glasses.  Samsung glasses won't work with a Panasonic 3D TV, and visa verse.
#5 of 6 Matt Hough
    Executive Producer
  • 11,022 posts
Posted September 11 2011 - 08:09 AM
Adam is correct. All brands of 3D players will work with all brands of 3D TVs. They don't have to be made by the same manufacturer. He's also correct about the active shutter glasses. You get the glasses that match your TV, and you'll be set.
#6 of 6 Imty
Imty
  • 3 posts
Posted September 13 2011 - 01:29 AM
Thanks guys for your help. Appreciated.
