Jump to content
Universal Remote will not control Dish Network box
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   winniw
winniw
  • 287 posts
Posted June 13 2011 - 04:56 AM
I have an Elite Screens ZR800D univeral remote and got it to work with my receiver, BD player and projector by using the learning mode. I cannot get the remote to work with my Dish Network box.  I tried using the Echostar codes and the learning mode.  While programming in the learning mode, it appears to be "learning" but when I try to use it, there is no response from the Dish box.  Why?
#2 of 3 OFFLINE   ZachAtDISHNet
ZachAtDISHNet
  • 1 posts
Posted June 17 2011 - 02:41 AM
Hello Nick,
My name is Zach Schultz and I work at DISH Network. There is one thing that we need to check. With universal remotes we need to make sure that the remote address on the receiver is set to 1 for the primary remote. To check this all you need to do is press the menu button on your DISH remote two times. That will bring you to a screen that says "System Info". You will see a line that says "Primary Remote Address", in the white box to the right of the line that will have a number in it. That number needs to be 1, if it is not we can change it by holding the SAT button on your DISH remote until all the lights light up. Once the lights light up release the button and the SAT button will be blinking, while it is blinking press the number 1 followed by the # button. The SAT button will blink 3 times. After it blinks press the record button 3 times and that number will change to one. Try your universal remote, if it is compatible with our equipment it should be working now. Let me know if you have any other questions.
Zachary Schultz
Internet Response Team
DISH Network
Tuesday-Saturday
06:00-14:30 MST
#3 of 3 OFFLINE   winniw
winniw
  • 287 posts
Posted June 18 2011 - 06:57 PM
Zack, Thank you very much for responding to my problem. I checked out the Dish receiver and it was set to 1.  There is a note in the universal remote's manual that states that it may not work with everything, due to some type of software conflict with some products... so I guess that's it. Thanks though.  I must say that in my experience, Dish Network's customer service has always been top-notch and I appreciate that. Nick
