Jump to content
power surge protector
5 replies to this topic
#1 of 6 OFFLINE   rockky3459
rockky3459
  • 10 posts
Posted May 24 2011 - 06:53 AM
i need help i need to purchase a power surge protector for my home theater
should i get the monster mp hdp 1800 or should i get the panamax m4300-pm
any help would greatly appreciated
thanks
#2 of 6 OFFLINE   winniw
winniw
  • 287 posts
Posted May 24 2011 - 07:07 PM
Consider this one, the APC H15 FOR $235.  It also has voltage regulation and weighs 22 pounds, compared to the 8 or 9 pounds of the ones that you listed.  It compares to the Panamax M5400 at around 1/3 the price.
Link: http://www.amazon.co...06306825&sr=1-1
#3 of 6 OFFLINE   Ottawa
Ottawa
  • 14 posts
Posted May 25 2011 - 11:11 PM
I don't know if you've decided or purchased anything yet.  But here's my 2 cents anyway.  The APC mentioned above is on the right track, I would definitely purchase an APC...but not the one mentionned by Nick.  1 reason.  Do you really plan to watch TV while the power is out?  Then don't get a battery backup system.  I decided to purchase a surge protector/line conditioner from APC myself.  The APC AV G Type Power Filter (http://www.apc.com/p...&base_sku=G5BLK) is a great product.  Surge protector and line conditioner.  What more do you REALLY NEED?
#4 of 6 OFFLINE   winniw
winniw
  • 287 posts
Posted May 26 2011 - 03:16 AM
The APC H15 is not a battery back-up system.
#5 of 6 OFFLINE   rockky3459
rockky3459
  • 10 posts
Posted May 26 2011 - 05:05 AM
thanks guys i still hae not made my decision yet but i'm kind of thinking of getting the panamx or the apc av 15 amp g type rack power filter,120 v
not sure which one yet
thank you nick & kevin you both have been very helpful
#6 of 6 OFFLINE   rockky3459
rockky3459
  • 10 posts
Posted July 15 2011 - 03:27 AM
quick question on the panamax m4300-pm when hooking it up to my system and everything is plugged in is there anything i have to do ? pretty much let it do it's own thing i see no control's on it ,no settings ? i know this sounds a bit dumb but i'm new to the home theater thing i have a panasonic tcp50 vt25 3d plasma denon 2311 ci sony blu ray player 3d s770 toshiba hd a30 panamax m4300-pm thanks for your help
