So I have a 52" Toshiba Regza, and it only has one analog audio output on it. I have a receiver which is currently connected to the tv output, and also a subwoofer which has the red/white inputs, but theres no way to get sound to that because my receiver doesn't have any outputs on it and the tv's outputs are being used by the receiver. My question is, could I use two y-cables like in the link below to split the audio to two different speakers and have audio coming out of both at the same time?
What I'm thinking is, buy two of the y-cables plug one into the white output and then both of the white cables going to the different speakers into the other end of the y-cable, and do the same with the red. Could I get both of them playing at the same time?
Here's the y-cable:
http://www.radioshack.com/product/index.jsp?productId=2103862#
Sorry it's a bit confusing, but any help would be great.
Here's the y-cable:
