RPBel
- Jan 23, 2011
- Roger
[SIZE= 14px]I have a room that is 20 x 30, with 15 foot high ceiling and wood floor. Mostly bookshelves and heavy drapes on one end. Have a 52" Sony TV (on the long side) and an audio system that is 20 years old. The TV speakers sound better than my audio system.[/SIZE]
[SIZE= 14px]I'm not too tech savvy, so need something I can easily put together, but don't need an out of the box system.[/SIZE]
[SIZE= 14px]I need the best sounds from bookshelf system I can get for $1,500 to $2,000. [/SIZE]
[SIZE= 14px]I looked at the Paradigm Cinema 110 five speaker set. Would you consider them a good choice? I assume I need some type of receiver with it? What would you suggest.[/SIZE]
[SIZE= 14px]I want to hook up my TV, Blue Ray, Wii, XM, and Apple TV all to the same system.[/SIZE]
