Jump to content
A wireless router, networking, LAN question
  • Please log in to reply
7 replies to this topic
#1 of 8 OFFLINE   DaveF
  • 16,321 posts
  • Real Name:David Fischer
  • LocationOne Loudoun, Ashburn, VA
Posted January 18 2011 - 03:20 AM
Can I distribute a wifi internet connection via wireless router to PCs connected to it by ethernet? I'm setting up an ad-hoc LAN in a test facility. The facility has a wireless guest network: on a laptop, connect to the network, open a browser, enter your guest id and password into the authentication page and get access to the web. I've got two PCs in this facilities current setup as a two PC LAN on a bog standard Linksys BEFSR41 wired router, so they can share data between each other. If I replaced that wired router with a wireless router, could I use the router to distribute the wifi web access to the two wired PCs? Or is it necessary to put a wifi card into a PC and set it up as an ICS host for LAN? I need to replace the router anyway -- I bought a 10/100 router and I found need a Gigabit LAN -- and we want to give these PCs web access. I'd like to kill two birds with one stone by replacing the 10/100 wired router with a 10/100/1000 wireless-n router. I'm out of my depth on this type of networking, so any guidance is appreciated!
#2 of 8 OFFLINE   Thomas Newton
Thomas Newton
  • 1,484 posts
Posted January 22 2011 - 05:38 PM
I don't believe that there is any standard for mixing and matching arbitrary access points to construct an extended network.  (The standards have the concept of an extended network, but are mostly concerned with the interface between the network "cloud" and wireless clients.) So the brand of the test facility access point may determine what brands you can consider, or whether wireless extension is even possible.  Beyond that, the administrators of the test facility LAN may not want you to extend their wireless LAN and potentially compromise their system security.  (They may be hostile to the idea of any "foreign" access point being hooked to their LAN, in any way, as it only takes one unsecured access point to grant access to someone sitting in a parking lot.)
#3 of 8 OFFLINE   mattCR
    Executive Producer
  • 10,400 posts
  • Real Name:Matt
  • LocationOverland Park, KS
Posted January 23 2011 - 12:44 AM
Dave, what you can do is get a router that will act not as an access point, but as a client, so it would receive in wifi and use it as a source  Basically, you could "homebrew" it, with something like ClearOS (http://ww.clearfoundation.org/ ) or find a router that supports being flased to DD-WRT which will also do it, but that's your options.
Ask Me about HTPC! (Threads in HTPC / PMs always responded to)
This signature is povided by MediaBrowser 3 Trakt Plugin: Media Browser 3
#4 of 8 OFFLINE   DaveF
  • 16,321 posts
Posted January 23 2011 - 04:44 AM
Thanks :) In this case the wifi system is specifically for "guests", such as myself. Given the modest complexity or using a wireless router for the connection, I'll just buy a wifi card for one or both computers and connect normally.
#5 of 8 OFFLINE   nolesrule
  • 3,084 posts
  • Real Name:Joe Kauffman
  • LocationClearwater, FL
Posted January 23 2011 - 07:47 AM
I'm not sure I clearly understood what you are trying to accomplish, but there are 2-zone wifi routers where one of the zones is firewalled off from the network and only allows internet access. I use one at home.
#6 of 8 OFFLINE   Scott Merryfield
Scott Merryfield
    Executive Producer
  • 11,268 posts
  • LocationMichigan
Posted January 25 2011 - 05:34 AM
I use a Netgear wireless "print server" to accomplish something similar in my house. The print server also provides four ethernet switch ports and can act as a bridge to connect to my wireless router. I use the device to connect two devices in my home theater rack to my home network without running ethernet cables across my house, since my router is in a different room from the home theater. You can purchase products called "wireless bridges" that accomplish the same thing. I used the "print server" instead, though, as it was only $30, while most products sold as a bridge were around $70 - $80, even though the print server is actually a bridge, too. You gotta love marketing. This may work for you, depending on what security restrictions are in place on the "guest" network to which you are attempting to attach. The guest network, though, may be configured to allow only a single MAC address per connection to prevent this type of "piggybacking". We employ this type of security on the network where I work.
#7 of 8 OFFLINE   Erick Branner
Erick Branner
  • 2 posts
Posted May 26 2011 - 08:13 PM
The post is pretty good. I really never thought I could have a good read by this time until I found out this forum. I am grateful for the information given.
web design | website design
#8 of 8 OFFLINE   sohaschon
  • 1 posts
Posted May 27 2011 - 06:48 PM
Your guidelines are good. It will help any person to make a choice for the web design without any hesitation. Thank you for your posts.
dissertation writing - dissertation help - write dissertation
