I need help with my remote setup (1 Viewer)
nitrox36
Grip
shawn
I have the following
Denon av790
Xbox 360
Ps3
Nuvico dvr
Htpc with window 7
I need a remote that will work with all my stuff is that possible
and i would like to have a lighting system for the room that will work with the same remote.
can any one help me?
Robert_J
Mississippi
Harmony Remotes.
Look at the X-10 home control systems. Some have IR remotes. The Harmonys are learning remotes and can learn almost any IR command if it is not already in the huge database.
Ertugrul
