Jump to content
Western Digital Livewire Review: Powerlines Really Do Work !
Hardware Review
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   Ronald Epstein
    Studio Mogul
  • 42,150 posts
Posted December 12 2010 - 10:16 AM
I live in a large multi-level home where my wireless
networking has had a certain degree of difficulty with
coverage.  I have a router that sits in my office on the
far upper level of my home whose wireless signal
drastically fades by the time I get to the family room
or outside deck located on the opposite lower end of
the house.
For years I have been unhappy with the poor speeds
and overall experience of using a laptop in the areas
I want to use it in the most.
But what was I going to do?  I don't have the expertise
to strand 500' worth of Cat5 cable across my home.
A friend at work told me that he was using a Belkin
powerline kit to feed Internet to his computer that
was located several rooms away from his router.
According to this friend, he was getting fairly good
connection speeds.
Now in case you have no idea what a powerline network
is all about, I invite you to read this Wikipedia article that
talks extensively about it.  In short, your home's electrical
system is used to transmit Internet data from a transmitter to
receiver.
Powerline networking has gotten a bad rap over the
years --- and rightfully so.  Initially it provided questionable
performance.  However, over the years, the technology
became standardized and as a result, there are better
performing products now in the marketplace.
Considering to go with powerline networking was my
absolute last choice.  However, the more reading I did
over the past week about the technology as well as
the raving reviews that have been posted about some
of the better powerline products, I decided I had nothing
to lose but try it out for myself.
Posted Image
The product I ended up purchasing was the Western Digital WD
Livewire.  Recent reviews on CNET and AMAZON have rated this
particular model as the very best available as of the writing of this
review.  Mind you, a newer chipset technology has just been approved
this year which means that there will be faster and even more effective
powerline kits being introduced shortly.   I was not going to wait.  At
a pricepoint of $100 I thought this could very well be the solution I was
looking for.
I have to say up front that I was very apprehensive about buying this
product.  From what I read, powerline technology can be hit or miss and
while many people have success with the technology, many see no
results at all.  Suffice to say, I opened the packaging very carefully
anticipating I was going to return it to Amazon.
Posted Image
The WD Livewire consists of two 4-port routing units with AC cords and short ethernet cables.
Posted Image
Posted Image
There are several huge advantages of going with the WD Livewire over other
Powerline models.  First, instead of being a big bulky unit with a plug directly
attached to its end, the detachable AC cord allows you to move the unit away
from the wall.  Another huge advantage is the fact that this is a 4-port outlet
that will allow you to use it as a hub to plug in up to 3 additional devices outside
of the primary Internet connection itself.
Setup could not be any simpler.  Simply plug one of the WD routing boxes into
an AC outlet and then connect it to your router via ethernet cable.  Then take
the second WD routing box and plug it into the AC outlet on the other side of
your home or in a secondary room within 2 minutes and watch the green connection
light come on indicating that a communication between the two units has been made.
All of this took less than 5 minutes once removed from the box without the
assistance of the supplied directions or Windows software whose purpose is
to monitor current connections and add new livewire modules.
There are two very important things you must know here.  First, you should not
plug these units into extension cords or surge protectors.  They will absolutely
degrade performance.   Also, both AC outlets that you choose must co-exist on
the same power grid in your home.   Momentarily, I will talk more about the problems
that will occur if you mix and match AC outlets on different grids.
Now let's see if this powerline kit really delivered the goods....
First, I took my Macbook Pro and ran speed tests to show its performance,
without the powerline, directly wired to my network.
Posted Image
This is what you would consider my normal wired connection speed to
my Verizon Fios network.
Posted Image
Here are the results after plugging my laptop directly into the powerline
router via cable at the opposite end of my house.  As you can see I did
not lose much signal here.   I found this to be highly encouraging for what
I was about to do next.
Posted Image
Since I wanted to expand the overall WiFi coverage at the opposite
end of the home I plugged in my Apple Airport Extreme to the newly
created powerline Internet connection.   I placed this combination near
the family room that I wanted to provide a stronger signal to.
For kicks and giggles, if you want to see all the advice I received
on accomplishing this task, please read my exchanges in this thread.
Really have to thank Bob Timmons for helping me out with this.
Now mind you, you can easily plug your laptop or networking device
directly into the ethernet port in the back of the WD Livewire for maximum
signal strength.
Posted Image
This speedtest shows how bad my WiFi coverage usually is in
the family room.
Posted Image
After establishing a powerline connection and using my Apple
router to extend it wirelessly, you can see how much the signal
dramatically increased.  It more than doubled.
The Apple iPads are notorious for having bad WiFi.  Unless you
are close to the source of the signal your iPad will exhibit a minimal
amount of signal bars.
Prior to hooking up my router to the powerline I was getting 11.50MB/s
download speed with one indicated bar of coverage.  After the powerline
addition it dramatically increased to full bars of coverage and 22.50MB/s
download speeds, very similar to the tests shown above.
A few moments ago I warned about using powerline networking with
AC outlets that are not on the same grid.   About 15 years ago we had
an extension put on our home that included the new family room I have
been trying to cover wirelessly.   A new addition means new wiring.  All
the electrical outlets associated with the addition are on a separate fuse
box.
Posted Image
Posted Image
The top box shows speedtest results from the WD powerline connected to
an AC plug that is on the same grid as the transmitter in the office.
The bottom box shows what happens if you plug the powerline into an outlet
that is not on the same grid.  You can see the dramatic signal loss.
CONCLUSION
I am really amazed here.  I did not think I would obtain the dramatic results
that I did.  I have effectively been able to expand my wireless coverage,
more than doubling the signal strength without having to use cable.
Of course, a few questions still remain.  Will the powerline provide consistent
signal strength or will it fluctuate due to line noise caused by appliances or other
electrical interference?  I haven't really had time to test the new coverage
extensively to figure that out.
Another concerns is power outages.  We go through several such outages
a year and I suspect that the powerline will have to be manually reconfigured
each time electricity is lost.  All that means is replugging both units into the
wall to establish a connection.  It sounds easy, but somewhat annoying when
you consider your home Internet resets itself.
All in all, you can bet that I am one happy camper here.  I am hoping this
technology will work equally well for those of you with same coverage problem
I have.  I would suspect just about everyone does.
Posted Image
Ronald J Epstein
Home Theater Forum co-owner
 Click Here for the latest/hottest Blu-ray Preorders  Click Here for our complete Blu-ray review archive
 Click Here for our complete 3D Blu-ray review archive Click Here for our complete DVD review archive
 Click Here for Blu-Ray Preorder Release Schedule  Click Here for forum posting rules and regulations
#2 of 12 OFFLINE   Parker Clack
Parker Clack
    Schizophrenic Man
  • 12,174 posts
  • Real Name:Parker
  • LocationKansas City, MO
Posted December 12 2010 - 10:51 AM
Nice write up Ron. I have been using a Netgear AV200 Powerline setup with my XBox 360 and HTPC to stream my recorded shows in MCE. I never could get a good signal from my wireless setup and the Netgear works about as well as a direct connection over CAT 5. I haven't had any issues with signal loss due to other components causing electrical interference and when I have lost power to the house I haven't had to reconfigure anything. I am sure that the WD Livewire will do the same or better. I do like the fact that this is a separate unit that you plug in via a cord instead of direct connection to the outlet.
"I tried to get my medical records from the company but they say they
are confidential and can only be released to other insurance companies,
pharmaceutical​ reps, suppliers of medical equipment and for some
reason the RNC."
#3 of 12 OFFLINE   DaveF
DaveF
  • 15,162 posts
  • Real Name:David Fischer
  • LocationOne Loudoun, Ashburn, VA
Posted December 12 2010 - 01:40 PM
Quote:
Originally Posted by Ronald Epstein [url=/forum/thread/306750/western-digital-livewire-review-powerlines-really-do-work#post_3760616]
Ok, seriously, interesting writeup. :) I had a somewhat similar issue initially: I'm in a bog-standard two-story colonial with my wireless router in the lower right office and I had bad wifi reception in my upper-right master bedroom. The problem, for me, was the router was on the floor behind a full filing cabinet. Twelve inches of paper was a very serious hindrance of the wifi signal. Moving the router to the top of the desk fixed everything, and I've got solid wifi throughout the house, in the basement and even sitting in my car in garage. I'm sure you explored your options, but I'd encourage anyone with some wifi problems to try some simple positioning changes on their wireless base station.
These powerline solutions have been out...I recall reading about them in the 90s, always with mixed reviews. I'm glad to hear that there's a kit like this that's robust. Running ethernet is a pain, but this is a literally plug and play solution. I'll keep this in mind if friends mention needing a better network solution.
#4 of 12 OFFLINE   mattCR
mattCR
    Executive Producer
  • 10,226 posts
  • Real Name:Matt
  • LocationOverland Park, KS
Posted December 12 2010 - 01:42 PM
I've also been using the Netgear Powerline networking for some time - and have converted several older facilities to using it as a means to get to hard to reach areas.. it's excellent.   Great write up Ron.
trakt.tv
Ask Me about HTPC! (Threads in HTPC / PMs always responded to)
This signature is povided by MediaBrowser 3 Trakt Plugin: Media Browser 3
#5 of 12 OFFLINE   Ronald Epstein
    Studio Mogul
  • 42,150 posts
Posted December 13 2010 - 03:37 AM
You guys are going to laugh. For the heck of it I called Verizon Fios.  Asked them what it would cost to have a tech come out and string Interntet cable across my home. I was quoted $135 with no added monthly fees. That's $35 more than what I paid for the powerline kit. No brainer here.  Going to return the powerline kit and go with a wired connection. That being said, I still think that the powerline was an exceptional alternative if this solution was not available to me.
Ronald J Epstein
#6 of 12 OFFLINE   DaveF
DaveF
  • 15,162 posts
Posted December 13 2010 - 04:11 AM
I had no idea that an ISP would do contract work for home cabling! That will be a better solution, even if slightly more expensive.
#7 of 12 OFFLINE   Keith Plucker
Keith Plucker
  • 1,071 posts
  • LocationSacramento
Posted December 13 2010 - 05:33 AM
How does security work with something like this? Any idea? For instance, if someone where to plug a powerline adapter to an outlet on the outside of your house, for instance, in the patio area, would they be on your network at that point? -Keith
As far as I'm concerned, it's a damned shame that a field as potentially dynamic and vital as journalism should be overrun with dullards, bums, and hacks, hag-ridden with myopia, apathy, and complacence, and generally stuck in a bog of stagnant mediocrity. - Hunter S. Thompson, 1958, from cover letter he wrote for a newspaper job.
#8 of 12 OFFLINE   Ronald Epstein
    Studio Mogul
  • 42,150 posts
Posted December 16 2010 - 05:16 AM
At $140 for what would amount to an hour of work it seems to me
that they would be happy to provide this service.
Keith, it's my understanding that the powerline adapter creates
its own security network.  There is a security button that you can
push on both units that secures it from anyone else tapping into
it.
Ronald J Epstein
#9 of 12 OFFLINE   mattCR
mattCR
    Executive Producer
  • 10,226 posts
  • Real Name:Matt
Posted December 18 2010 - 12:38 AM
-Keith
Well, yes.. if someone plugged in a powerline adapter to somewhere else in your house, they could get on.. if it's a powerline network that allows multiples..  Most powerline networking kits are one to one.. one sender, one receiver, not multicast.   But let's say you have a multicast powerline network... it could be done.   But this is the oldest kind of network security.  If you can't spot a guy haunched down on your patio with a laptop, you have other security issues :)
trakt.tv
#10 of 12 OFFLINE   ZeroZero7
ZeroZero7
  • 2 posts
Posted March 20 2011 - 02:33 AM
Hi Ronald,
Kudos for your great review on WD Livewire! Btw..I would like to share with you that recently I viewed this video on YouTube and this dude did a testing on WD Livewire and claims that they have found the ultimate solutions for most PLC adapters. Check him out at this link:  If what his claims are "true" then it will be great news for all plc fans.
#11 of 12 OFFLINE   Ronald Epstein
    Studio Mogul
  • 42,150 posts
Posted March 20 2011 - 03:13 AM
Wai Kin, Welcome to the forum and thank you for the kind words. Could you explain to me a little about PLC?  I know very little about PLC adapters.
Ronald J Epstein
#12 of 12 OFFLINE   ZeroZero7
ZeroZero7
  • 2 posts
Posted March 22 2011 - 04:15 AM
Hi Ronald,
Fyi...you may find more information about plc (powerline communications) at this link: http://en.wikipedia.org/wiki/HomePlug. This plc adapters technology have been around for about 11 years already. The most widely used plc adapters are from homeplug. These PLC adapters started with the 14Mbps (chipset) way back in the year 2000 and eventually progresses to 85Mbps (Turbo), and later to the 200Mbps (in 2007), and now 500Mbps and 1000Mbps (Gigabit). Most of these PLC adapters peformance (throughput) are somehow very susceptible to noises in the powerline and also noised induced into the powerline (like noises generated by the air conds, mobile phone charger, laptop charger, surge protectors, hair dryers, vacuum cleaner, water pump, light dimmer, etc.
With these noises the performance of the plc adapter can deteriorate further making streaming a Full HD (1080p) not quite possible. Even if possible you may not get the smooth streaming of the video. I hope the wikipedia on homeplug can tell you in much more details on plc.
Cheers and best regards!
Also tagged with one or more of these keywords: Hardware Review
