Jump to content
subwoofer question
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   ralphPerez
ralphPerez
  • 88 posts
Posted December 06 2010 - 02:55 PM
Wondering what is the advantage or disavantage to connect the speakers to the subwoofer??? Thanks,
Ralph Perez
#2 of 3 OFFLINE   Jason Charlton
Jason Charlton
    Producer
  • 3,323 posts
  • Real Name:Jason Charlton
  • LocationBaltimore, MD
Posted December 07 2010 - 02:26 AM
Generally, you connect your main speakers to the speaker terminals on the subwoofer because you have to, not because you want to.
You do this on older receivers or stereo receivers that do not have a dedicated subwoofer output.  Instead, you take both the left and right front speaker outputs and run them both to the subwoofer.  The subwoofer's internal crossover pulls the lower end of the frequency spectrum for its own use, and passes the higher frequencies on to the main speakers.
For newer receivers that have a dedicated subwoofer output, you're best off connecting your speakers that way - letting the reciever handle the crossover and sending output for each speaker separately.
Are you new to the Home Theater Forum? Stop by the New Member Introductions area and introduce yourself! See you there!
#3 of 3 OFFLINE   ralphPerez
ralphPerez
  • 88 posts
Posted December 07 2010 - 12:05 PM
Thanks for the reply, it makes sence but heck they are still adding the speaker hook up on a 3D receiver, you would think that they would not have the speaker terminals oh well who am I.
Ralph Perez
