Jump to content
Cary Audio Design DVD-7 Audiophile DVD Player
No replies to this topic
#1 of 1 OFFLINE   Jason Monette
Jason Monette
  • 266 posts
Posted October 28 2010 - 03:01 AM
Cary Audio Design DVD-7 audiophile dvd player.  I will arrange pick up or will ship with insurance at buyers expense.   http://www.caryaudio...inema/DVD7.html   The Cinema Series DVD 7 is a high performance DVD player that offers 1080p video from regular DVD disks. It will work with ‘early adopters’ video displays. Linked video output settings from 480p to as high as 1080p are available from the HDMI and RGB+HV outputs plus 480i to 1080p settings from the interlaced or progressive component video outputs. In addition, the DVD 7 is an audiophile grade CD player that is using Burr Brown 1792u digital to analog converters to decode CD disks.   VIDEO SPECIFICATIONS   Playback System DVD Video/Video CD/CD/DVD-RW/DVD+RW/CD-RW Video DAC chips HDMI/RGB/CV (3 Video chip sets) Dual Faroudja Video Format Converter/HDMI Dual 12 bit/216 MHz/RGB 12 bit/108 mHz Component Video (CV) Video S/N 78.5 dB Video Signal Resolution 540 TV lines, DVD Signal Format System PAL / NTSC Composite Video Output 1.0 Volt peak to peak, 75 Ohm, sync negative S-Video Luminance Signal 1.0 Volt peak to peak, 75 Ohm load Color Signal 0.286 Volt peak to peak, 75 Ohm load Component Video Output Y Output Level 1.0 Volt p-p, 75 Ohm load Pb Output Level 0.7 Volt p-p, 75 Ohm load Pr Output Level 0.7 Volt p-p, 75 Ohm load AUDIO SPECIFICATIONS   Master Clock Jitter Below measurable levels Digital/Analog Converters Burr Brown PCM 1792u  Analog Filter Third Order Bessel Analog Outputs RCA, XLR stereo Frequency Response 2-22 kHz Fs = 48 kHz 2-44 kHz, Fs = 96 kHz Amplitude Linearity 0.1 dB (20-20 kHz) Phase Linearity 3.0 degrees (20-20 kHz) Dynamic Range 120 dB (1 kHz) Signal to Noise Ratio 120 dB (1 kHz) Channel Separation 108 dB (1 kHz) THD 0.0008% (1 kHz) Audio Output Level 2.2 V rms. RCA, 4.4 volts XLR DIGITAL AUDIO OUTPUT   Coaxial Digital Output Dolby Digital/DTS/LPCM 200 mV rms. @ 75 Ohms Optical Digital Output Dolby Digital/DTS/Toslink AC Power 117/234 Volts AC, by market Power Consumption 32 watts - Operation 5 watts - Standby Video Output Modes Component Video: 480i, 480p, 720p, 1080i, 1080p   HDMI/RGB + HV: 480i, 480p, 720p, 1080i, 1080p, 800x600, 1024x768, 1280x1024, 1366x768 Chassis Black enamel steel chassis, silver anodized aluminum front panel (black optional) Weight 35 lbs Dimensions 18" W x 4" H x 14" D
The Sony STR-DA777ES Page
My DVD Collection
"The Choices we make, dictate the life we lead!"
