Jump to content
SONY STR-DN1000 RECEIVER - SPEAKER PLUGS !
5 replies to this topic
#1 of 6 OFFLINE   boromac
boromac
  • 3 posts
Posted October 09 2010 - 06:18 PM
Hi there everybody,
I'm just unboxing this device and I wonder what is the model of speaker connector that works fine here.
There are many models in the market, which ones should I take ???
Here's a picture of device's back.
http://static.hometh...um.com/imgrepo/
This is my first home system, but I don't want just round wires around the connectors. I'd like to make something with bit more quality, with those plugs.
Can you help me since there are many models from MONSTER CABLE, ACOUSTIC RESEARCH, etc.
MC
http://www.monsterca...ay.asp?pin=4582
(this one above has a "fatty" middle, looks won't go inside the space...) (can't it be pressed strongly to enter ???)
http://www.monsterca...ay.asp?pin=4583
http://www.monsterca...ay.asp?pin=4584
AR
http://www.araccesso...vity/?sku=AP397
http://www.araccesso...vity/?sku=AP396
And below I'm adding the speakers to be linked with this receiver.
SONY SS-FCR6500, SS-SR7000 (x2) e SA-W3000
SS-FCR6500 = frontal big speaker = Speaker Terminal Type : Binding Post
SS-SR7000 = surround and central speakers = Speaker Terminal Type : Push Type
So, which connectors should I take ?
If there is already a topic regarding this, please let me know, 'cause I couldn't find.Hope you can help.
Thank you.
#2 of 6 OFFLINE   boromac
boromac
  • 3 posts
Posted October 09 2010 - 06:42 PM
Hey,
just adding the speakers that I'm connecting this device:
SONY SS-FCR6500, SS-SR7000 speakers and SA-W3000 subwoofer.http://static.hometh...um.com/imgrepo/
SS-SR7000 (surround and central) = Speaker Terminal Type : Push TypeRegarding speakers
SS-FCR6500 (big ones) = Speaker Terminal Type : Binding Post
Thank you.
#3 of 6 OFFLINE   boromac
boromac
  • 3 posts
Posted October 09 2010 - 06:48 PM
Hey,
just adding the spearks to be linked with this receiver.
Hope you can help.
Thank you.
#4 of 6 OFFLINE   CaitSurround
CaitSurround
  • 2 posts
Posted October 09 2010 - 10:38 PM
I've always used Monster cable for everything that I do audio wise. Generally for attaching to the back of an amplifier I have mostly used gold plated connections and as for the post connections I just trim the cable sheaths and try to do a neat tidy job with a good contact all round as the rear of my speakers are the type that pinche the cable directly and don't require an additional attachment.
No doubt many other types of cable are suitable but Monster is my personal preference.
#5 of 6 OFFLINE   Al.Anderson
Al.Anderson
  • 2,180 posts
  • Real Name:Al
Posted October 09 2010 - 10:48 PM
You're over-thinking this one.  Any banana plug will work just fine; you won't hear any difference in the sound.  If you really feel the need to go high end, get a connector with gold plating.  And then get the cheapest in that category (which won't be Monster).
Note that I wouldn't get the u-shaped connectors.  Banana plugs are so much easier, and since you're taking the time to attach a connector you might as well use one that makes your life easier.  (Some receivers don't have banana plug holes, then you'd use the other.)
#6 of 6 OFFLINE   dc88
dc88
  • 13 posts
Posted October 17 2010 - 07:04 AM
check out mono price .com cheapest place around and good quality i ordered 100 feet of 12 gauge wire and like 15 pairs of connectors from them and its was 55 shipped to my door . use banna plugs for all the speakers going into the reciever and then you can use pin type connectors for the push type terminals and bannana's for the binding post terminals that's what i did .
