Dudelike89
Grip
- Aug 2, 2010
- Andrew
Hey all! My entertainment center could use some new lighting. The light fixtures are these small, maybe 2 inch diameter light fixture with some type of odd bulb. I think it might be xenon or something. Anyways, the bulbs seem quite rare and are a pain to replace. You can't touch them with your fingers or the life will be dramatically decreased. The light fixtures are facing the ground and are placed inside holes of a wood board. On top of the board is an outlet that is controlled by a light switch, which are where these light fixtures are plugged into. I'm trying to find new light fixtures. I was thinking maybe some nice LED lights. I've been looking online, but I haven't been able to find anything. If there is any one who can help, I would appreciate it.
The holes in the wood for the light fixtures are 6 centimeters in diameter.
Let me know if you'll need more info to help me.
Andrew
Andrew
