Jump to content
Sign up for a free account!
How do I configure my PC HMDI output for surround sound?
  • Please log in to reply
11 replies to this topic
#1 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted August 11 2010 - 02:09 PM
Hi all,
New to the forum, but I have some experience with PCs and Hometheatre, and now I want to bring them together.
I just purchased an entry level laptop (HP G62 series) and it has an HDMI output. I connected the HDMI cable to my home theater and I got both video and audio working through it. The problem: Audio was only in stereo.
I went to the control panel and tried to reconfigure my sound from HDMI and there was "surround" option that was dull and unclickable. My computer is only letting me send a 2.0 signal through HDMI. Does anyone know how I can change this (or if I can change this?)
Sound driver is  ATI High Definition audio device
OS: Windows 7 64 bit.
Main processor ADM Athalon Dual Core P320 2.1GHz
Any help would be great - I would like to know if my hardware is capable of 5.1 (or ideally 7.1)  thanks
Ryan
#2 of 12 Parker Clack
Parker Clack
    Schizophrenic Man
  • 12,068 posts
  • Real Name:Parker
  • LocationKansas City, MO
Posted August 26 2010 - 09:14 PM
I believe your problem is that you don't have the codecs required for 5.1 audio over HDMI installed. I would download the latest display driver from ATI.
http://support.amd.c...ob_win7-64.aspx
It should load the proper audio codecs for you.
Hopefully mattCR will drop in to this thread as he knows a lot more about this than I do.
"I tried to get my medical records from the company but they say they
are confidential and can only be released to other insurance companies,
pharmaceutical​ reps, suppliers of medical equipment and for some
reason the RNC."
#3 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted August 27 2010 - 03:02 PM
Thanks for the link. I'll need to review the specs of the laptop more carefully to discover which driver update I'll need. if all else fails, I'll try and contact customer service and hopefully they can help me. Thanks for the input! Much appreciated
#4 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted September 04 2010 - 06:18 AM
Hmm, read all of the release notes on the driver updates and non of theem mentioned an HDMI audio fix, or audio fixes at all for that matter. Also, the download warnings and possible failures that could result is unsettling. I have contacted AMD's costumer service directlly and hopefully they will reply to me some time next week.
Thanks again,
Ryan
#5 of 12 mattCR
mattCR
    Lead Actor
  • 9,996 posts
  • Real Name:Matt
  • LocationOverland Park, KS
Posted September 04 2010 - 10:07 AM
If you're running Windows 7, there are some important things you must do.
Do this:
Right click on the speaker icon on your task tray.
Choose Playback devices
http://static.hometh...um.com/imgrepo/
Then, you need to make sure 5.1 or 7.1 is chosen.  It's going to be unlikely you'll see 7.1.  NOTE:  If you ONLY see stereo, that's OK!  We'll deal with that in a second.
Now that you've done that, right click back on your device (ATI HDMI) and go to properties..
Make sure you see "Encoded Formats" and that it lists DTS and Dolby Digital.
This means it's prepared to pass through those formats in bitstream over your HDMI.
Now, this will handle ONLY output from Windows Native formats (ie, WMV, etc. as well as TV.. )  Most of your TV is going to be 2 channel if it's PCM audio (non-HD) but the rest will be DD if it passes through.
This will also pass through bitstream audio from DVDs.
But, let's say you want to MAKE SURE this happens.
First, download the newest drivers at ATI: http://ati.amd.com/ you'll want the 10.8 catalyst.
After you have that installed, let me know how it goes, and we can move on to the kind of file formats you're trying to decode and the results that you want.  (ie, how to setup FFDShow, etc. if you are worried about other file formats)
trakt.tv
Ask Me about HTPC! (Threads in HTPC / PMs always responded to)
This signature is povided by MediaBrowser 3 Trakt Plugin: Media Browser 3
#6 of 12 mattCR
mattCR
    Lead Actor
  • 9,996 posts
  • Real Name:Matt
Posted September 04 2010 - 10:24 AM
Doing a quick look tells me your laptop is most likely an AMDVision series.  (ATI HD4200/3300).   This means that it will only pass UNCOMPRESSED audio as 2 channel over HDMI (common) and Bitstream audio (DD/DTS) in bitstream format, to be decoded by a reciever, etc if detected.  But the HDMI will not output uncompressed multichannel on this model.
If your issue is getting bitstream to correctly function with your receiver, let me know, and we can help you out ;)
  • Utsav Sabharwal likes this
trakt.tv
#7 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted September 05 2010 - 07:24 AM
Thanks Matt,
I really appreciate the time that you have taken to help me with this.
I downloaded the 10.8, installed it but it still is a no go.
In that second window (second window pictured in your post), I still only have stereo as an option.
I'm not sure what I am doing wrong here.
When I right click on the speaker icon, click playback devices, click HDMI, click properties, click properties (again), click driver it tells me I am running version 7.11.0.7703 dated for 21/01/2010.
I don't think this is the right driver given that catalyst 10.8 was released on 25/08/2010.
I've run the installer 3 times. And each time it tells me install was successful.
Also, on the Driver tab, there is an "Update Driver" button which is grey and unclickable. Do I then assume that because it is unclickable that I am running the most up-to-date driver for this machine?
Any thoughts would be greatly appreciated.
#8 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted September 05 2010 - 07:49 AM
Yes, it is an AMD Vision. It is running Radeon HD4250
Now with your comment here, are you saying that I won't be able to get the audio set up to display multichannel because I'm guessing the whole setup is run as uncompressed audio? To use terms that I understand - the HDMI will only do analog style sound in 2 channel, but digital it may do in multichannel?
(still trying to make sense of this here, so bear with me) but it sounds like If I drop a DVD in, the DVD could very well send a 5.1 bitstream out the HDMI (DD/DTS)? I'm I getting this right? Since it can only do 5.1 as a bit stream, it won't give me the option to see multi-channel out via the HDMI?
I'm fine with it doing a 5.1 bit stream. I'm just wondering how or where I set that bugger up.
My set HT set up isn't as straight forward as it could be.
It is an older Yamaha receiver without HDMI inputs. But my TV has HDMI in and optical out. The optical out on my TV send a 5.1 signal to my receiver on all over the air digital channels. So I know my TV allows a bitstream to pass through it from the tuner. But, the TV has no digital inputs other than the HDMI (my DVD player is connected straight to my receiver through an optical cable) . . . could the TV be a bottle neck in this process too? Could it be that because my TV does not have built in bitstream decoders that it is sending a message through the HDMI that all it can handle is 2 channel uncompressed? Does the device that the computer connects to need to be the device that decodes the bit stream, or can it just be a gate way to the decoder?
I have my Yamaha surround decoders set to automatic and it works like a charm. To this day my Yamaha has recognized and decoded every bit stream that my stand alone DVD player has thrown at it. So I don't think the issue is my receiver.
So did all of this information make things more complicated? Or is it just too much information now :)
Thanks again,
Ryan
#9 of 12 mattCR
mattCR
    Lead Actor
  • 9,996 posts
  • Real Name:Matt
Posted September 05 2010 - 08:17 AM
Correct.  A DVD (or content with a digital stream, like HDTV, or WMV and other content with an AC3 or DTS track, like in an MKV) will send out Bitstream over HDMI, for 5.1 (or 6.1 "EX" format).
But the HDMI on a 4250 doesn't support multi-channel ANALOG audio, (uncompressed) so if you're pitching out say, windows audio, etc. it will always be 2 channel and dependant on your receiver to make it Dolby Pro Logic.
IF you do not like this, and you want everything bitstreamed as Dolby Digital 5.1, you can run a conversion step (via FFDShow) but it's a bit overly complex with almost no rewards, except that it does the processing inside your PC instead of letting your receiver make the changes to DPL.   That's up to you, if you're interested in that I can walk it through.  (if you have a very low end receiver, this may be an option)
Have you popped in a DVD to see if your receiver flags it as DD or DTS
trakt.tv
#10 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted September 05 2010 - 10:08 AM
Thanks Matt,
Great to know the limitations of my laptop right up front.
I gave it a whirl. I threw in a DVD and at first it was just 2 channel - but then I went into the Audio settings of the player and turned decoding off and voila the receiver detected 5.1 (I don't remember if it was DD or DTS,) I saw six icons appear on the receiver indicating the channels that the incoming signal was from. So that is good enough for me! Interestingly enough, as the DVD started, Cyberlink Power DVD (the player that came with the laptop) informed me with a pop-up box that this version of the program does not support 5.1 digital output. I clicked okay, and i looked at the receiver, and it was very clear thatthe receiver was detecting a 5.1 signal . . . so I'm not sure what that is all about . . . everything was working like my typical stand alone player - all of the opening menus and previews were typically in stereo, and when the movie itself began, it detected 5.1. So I'm not really sure what that message is all about.
The short of it, is my HDMI is capable of passing a decoded 5.1 out, and my TV faithfully passes the 5.1 in through the HDMI and out through the optical.
Now, my next task is to figure out  . . . upconverting: Does cyberlink do it?
Thanks for all of your help Matt,
Ryan
#11 of 12 mattCR
mattCR
    Lead Actor
  • 9,996 posts
  • Real Name:Matt
Posted September 10 2010 - 11:44 AM
Ryan
Just the reverse.  Your system cannot decode the AC3 or DTS.. it just passes it out as SPDIF over HDMI, (digital for your receiver to decode).  Cyberlink is telling you it can't decode it (so it doesn't) it just passes it encoded through HDMI for your receiver to decode (and it does, thus the 5.1)  So good deal!
And yes, Cyberlink upconverts; it uses different methods to do it but it will upconvert to your native windows resolution.
trakt.tv
#12 of 12 MalteseChicken
MalteseChicken
  • 26 posts
Posted September 11 2010 - 01:51 PM
Thanks!
The message seems silly though since the computer only has 2 speakers, I'm not sure why any would want the computer to decode 5.1 to 2 speakers . . . but I suppose there would be somebody out there who would select the 5.1 bit stream and then wonder what's wrong with the computer because they can't hear any sound . . . so I guess for the person who might mess with the settings and not understand what they mean, that message box might help them figure it out (actually for that matter, I should probably default the settings to 2 channel analog for any time my wife might want to use this as a stand alone DVD player - I can imagine coming home to her insisting that we need to get the laptop repaired because the sound doesn't work on DVDs.)
Thanks again for bringing clarity to what should have been obvious to me.
Ryan
