bubblebuddyi
Grip
- Jun 26, 2010
- james
Hello,
My problem is this:
I have a subwoofer hooked up to my left and right tweeters (to help pick up mid-high frequencies) and surprisingly it does work well. The problem is when I sit in my "sweet spot" I can barely hear the frequencies. They either absent or very weird sounding (like its rattling my head). But, if I stand in my "sweet spot" I heard them loud and clear. I tried moving the sub to different areas, but I am very limited on space. Here's what I tried. Moved it to the right of the TV, in the corner. Moved it to the left side of the TV, which is a little more than in the middle of my room.
Also, I think the sub design has a lot to do with the sound. The design is like this: The actual speaker is on the right side of the closure, and the hole (whatever you want to call it) is on the front. I can supply pictures of setup if needed.
-Thanks
My problem is this:
-Thanks
