Jump to content
Crossover settings for subwoofer
9 replies to this topic
#1 of 10 bubblebuddyi
bubblebuddyi
    Extra
  • 18 posts
Posted June 26 2010 - 07:43 AM
Hello,
      I've done my fair share on reading about the crossover settings for both the amp and subwoofer, and I have my amp and subwoofer setup like this:
Subwoofer settings is turned to max (120 I think)
Amp settings is on 80.
Now my situation is this:
The surround sound speakers i'm using are very cheap and crappy when it comes to bass. I'm not sure what frequencies they pick up for the lowest. How should I set my amp's crossover to help fill in the gaps between bass without losing my nice, low bass?
I haven't tried anything yet, I wanted to get expirenced help before I started messing around with it.
Also, there is equalizer adjustment for all the frequencies of the speakers (not subwoofer) Does anyone have any recommendations on how I should set them for crappy, cheap speakers? The frequencies are:
63HZ
160HZ
400HZ
1KHZ
2.5KHZ
6.3KHZ
16KHZ
-Thanks for the help.
EDIT:
I just found the SPECS for the speakers i'm using, and the frequency range is 140Hz~20KHz. Does that mean I should put the crossover at 140Hz?
And also, my front speakers are different than my rear speakers. The rear speakers are even crappier! The sound is "hollow" that comes out of all the speakers, but worse out of the rear ones. What adjustments can I do to get rid of that "hollow" sound the best?
#2 of 10 gene c
gene c
    Producer
  • 5,700 posts
  • Real Name:Gene
  • LocationBay area, Ca
Posted June 26 2010 - 09:14 AM
It would be helpful to know what equipment you have.
It looks like your receiver only offers one crossover setting for all speaker groups, is this correct?
Does your receiver have an automatic setup/eq feature like Audyssey, MCACC or EZSet/Eq?
Does the receivers equilizer effect all the speakers at the same time can you set each speakers eq separately? If you can set them individually then I'd set the 63 hz band of the eq for the surround speakers as low as possible. That should help protect your cheap (and crappy /img/vbsmilies/htf/smile.gif ) surround speakers.
As a last resort you could get a couple of cheap (and crappy /img/vbsmilies/htf/smile.gif ) in-line "bass-blockers" and splice them into the surround speakers positive speaker wire.
"Everyday room": Panasonic 58" Plasma, Dish HD DVR, Pioneer Elite vsx-23, BDP-23 BR, dv58avi universal dvd player, Paradigm Studio 20 V1, CC-450, Dayton HSU-10 subwoofer.
"Movie/Music room": Toshiba 65" DLP, Dish HD receiver, Marantz 7005, CC-4003, BD-7006, Polk LSI25's-LSi7's-LSiC, 2 original Dayton 10" "Mighty-Mites" subwoofers. (subject to change without notice).
Also have  MB Quart Vera VS05 +.....too much to list. Help me.
#3 of 10 bubblebuddyi
bubblebuddyi
    Extra
  • 18 posts
Posted June 26 2010 - 09:19 AM
My receiver doesn't have any automatic setups, except for EQ but their like "natural, flat, front". The equalizer does have separate adjustments for each speaker. I have the LFE settings on subwoofer only.
I updated my thread with the specs of my front speakers.
-Thanks
Also, are these the "bass blockers" you're talking about?
http://www.radioshac...r resistor&sr=1
And how do I know which one I should buy?
#4 of 10 thundercare10
thundercare10
  • 1 posts
Posted June 26 2010 - 10:30 AM
http://www.houseofpain.com
#5 of 10 sweetdrops
sweetdrops
  • 1 posts
Posted June 26 2010 - 10:36 AM
#6 of 10 gene c
gene c
    Producer
  • 5,700 posts
  • Real Name:Gene
Posted June 26 2010 - 12:04 PM
"My receiver doesn't have any automatic setups, except for EQ but their like "natural, flat, front". The equalizer does have separate adjustments for each speaker."
In that case I would do as I suggested earlier and set the 63 hz band for each surround speaker to it's lowest setting like -6 or -12.
"Also, are these the "bass blockers" you're talking about?"
No. I mean something like these from Crutchfield. They're usually found in the car audio section. But you shouldn't need them if you can set the eq for the surrounds as I suggested.
"I just found the SPECS for the speakers i'm using, and the frequency range is 140Hz~20KHz. Does that mean I should put the crossover at 140Hz?"
If that is for the front speakers then yes, set the crossover to maybe even 150. The crossover should be set a little higher than what the speakers can handle.
"What adjustments can I do to get rid of that "hollow" sound the best?"
Your only hope is the bass/treble controls and equilizer but there's no way I or anyone else could guild you on those adjustments from a forum. And an eq can only do so much. You know, you can put lipstick and eye shadow on a pig...but it's still a pig  /img/vbsmilies/htf/smile.gif   . But the eq should help a little bit.
#7 of 10 jotereh
jotereh
  • 2 posts
Posted June 26 2010 - 12:30 PM
http://www.mavenir.com/
#8 of 10 jotereh
jotereh
  • 2 posts
Posted June 26 2010 - 12:35 PM
#9 of 10 bubblebuddyi
bubblebuddyi
    Extra
  • 18 posts
Posted June 26 2010 - 03:38 PM
Alright thanks. Any recommendations for the EQ settings?
#10 of 10 gene c
gene c
    Producer
  • 5,700 posts
  • Real Name:Gene
Posted June 26 2010 - 05:09 PM
There's no way to advise someone on where to set an eq without being in the room. All I can say is to play with it a little and see what happens. I f you think you messed it up, reset everything to zero and start again. "Hollow" sounds like a mid-range issue but I'm just guessing.
