Jump to content
Sound proofing icynene insulation
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   PuffnStuff
PuffnStuff
  • 1 posts
Posted June 12 2010 - 05:29 PM
Hi wondering if someone could answer this...I have an exterior basement wall where I plan to build a 2x4 stud wall with a 2" gap between the stud wall and the exterior brick wall. I want to have a foam insulation sprayed into the stud wall but am wondering if the insulation contacts the exterior wall does it negate the purpose of the 2" gap? Thanks in advance
#2 of 5 OFFLINE   SlapMan
SlapMan
  • 1 posts
Posted December 04 2010 - 05:29 AM
Hey puff, I'm building a house myself, and I watch alot of HGTV shows like Holmes on Homes.  Everything I've seen and heard, including talking to an Icynene installer is that you DON't want an air gap between the brick/concrete and the icynene.  The spray foam acts as a vapor barrier and insulation. My suggestion would be to spray the icynene directly to the brick/concrete.  The air-gap to the back of your studs will prevent any thermal transfer between the studs and the brick.  This is the 'best practice" for insulating basement exterior concrete/brick walls.
#3 of 5 OFFLINE   Adam Gregorich
Adam Gregorich
    Executive Producer
  • 15,069 posts
  • LocationThe Other Washington
Posted December 09 2010 - 07:01 PM
Welcome to Home Theater Forum Daniel and Matt
 You have fine taste in television Matt!
#4 of 5 OFFLINE   Cees Alons
Cees Alons
    Executive Producer
  • 18,857 posts
  • Real Name:Cees Alons
Posted December 09 2010 - 09:09 PM
??? Someone replied to him yesterday, but I doubt he will still be around to read it..... Perhaps he's a victim of the FB-connection improvement? Cees
#5 of 5 OFFLINE   bartoneblaze
bartoneblaze
  • 3 posts
Posted May 29 2011 - 10:29 PM
No there is no effect of foam insulation sprayed on other wall.The Icynene Insulation its superior fit makes it an ideal sound proofing system, reducing airborne sound transfer through the roof, floor and walls. Outside noises such as road traffic and trains stay outside.
