HD projector problem (1 Viewer)
TitanTn
Rob
I have an Epson Powerlite 700 LCD HD projector. Tonight it fell about 2 feet from it's stand and obviously now I'm having a problem. The lamp comes on, and then after a few seconds it enters the overheat mode and the fan kicks on. The power light turns a solid red and the temp light is flashing red. The limited user manual says that there is something wrong with the temp sensor. I'm not afraid to crack it open and work on it myself, but I don't know what I'm looking for. Can anyone point me in the right direction? Thanks.
Rob
Michael TLV
THX Video Instructor/Calibrator
Calgary, Alberta
Michael Chen
Greetings
Repair time ... there will be few repairmen on this forum. Sorry to say.
regards
Steve Berger
The problem with projectors is that the manufacturers have always insisted that they be serviced back at the factory as a "ship-in" product so most traditional servicers never see them.
Generally there is always at least one fan running at all times so I would suspect that it isn't now. About the only thing you could do is disassemble and inspect, looking for unplugged circuit boards, disconnected plugs and jacks, jammed fans, or misplaced covers and shields.
Jason Charlton
Baltimore, MD
Jason Charlton
Careful! Be sure to check the warranty information before cracking it open (if it's still under warranty). Often times opening it up voids everything.
acinstallation715
