Jump to content
64bit capacity vs 32bit
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Chris888
Chris888
  • 2 posts
Posted October 31 2009 - 01:36 PM
Hi, I've been doing a lot of searching and found a similar thread here so I registered to ask the question. I'm upgrading my laptop from 32bit windows vista to 64bit windows 7 and have been trying to find what my new RAM cap will be based on the motherboards cap. Everything I'm finding is listing the restriction at 4G but those points are also referencing the 4G cap of the 32 bit system. Everywhere I look at for the 64 bit systems says at least 8 but I'm sure that there's a hardware requirement for being able to go that high. My mother board is a Dell Inc 0UW306 and it takes  DDR2 PC2-5300 or DDR2 PC2-6400 Thanks, Chris
#2 of 3 OFFLINE   Keith Plucker
Keith Plucker
  • 1,079 posts
  • LocationSacramento
Posted October 31 2009 - 05:01 PM
 I believe that board uses the Intel PM965 chipset. If that is correct, 4GB is the max supported by the motherboard according to this page:
http://ark.intel.com...br type="_moz">
-Keith
As far as I'm concerned, it's a damned shame that a field as potentially dynamic and vital as journalism should be overrun with dullards, bums, and hacks, hag-ridden with myopia, apathy, and complacence, and generally stuck in a bog of stagnant mediocrity. - Hunter S. Thompson, 1958, from cover letter he wrote for a newspaper job.
#3 of 3 OFFLINE   Chris888
Chris888
  • 2 posts
Posted October 31 2009 - 05:20 PM
Great. That clears that up for me. Thanks for your help Chris
