Jump to content
sound proofing a wall
6 replies to this topic
#1 of 7 OFFLINE   paries
paries
  • 8 posts
Posted October 03 2009 - 05:38 PM
hello, i am hoping someone has some ideas of experience
So i converted my garage to a theater room.
My house is 20 ft from my Neighbours bedroom. They call us and complain if we are watching a movie with lots of bangs/explosions.
So i looked at the wall that us
separating us.
it is just a normal garage wall , with siding-->that blue foam panel--> some cheap insulation and then drywall on the inside.
So am looking for some ideas
i did a little google'ng .
I am wonder if someone has done something simular and if it worked.
I really can not alter the room on the inside. It is completely finished.
so here are a couple of options that i have found
http://www.foampower.com/store/two_component/slow_rise.html
pretty expensive (going to be about $700)
or this may be an option, if i take down the siding on one wall and place this stuff and then put the siding on top of it
http://www.soundisolationcompany.com/sound-solutions/walls/barrier/
Thanks for any suggestions
#2 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,160 posts
  • Real Name:Robert
  • LocationMississippi
Posted October 04 2009 - 12:04 AM
The Home Theaters and Projects section has a LOT of discussion on soundproofing.  Do a search on QuietRock and you should find the different threads.
But one wall won't help with the bass.  You will have to soundproof the entire room to contain it.  To properly do that it will cost you well over $700 which you think is expensive.
#3 of 7 OFFLINE   paries
paries
  • 8 posts
Posted October 04 2009 - 04:54 AM
 so am i completely wasting my $$ buy doing the one outside wall without doing the rest of the room? will it not help at all?
i am not trying to keep the sound out of the house just my Neighbours bedroom, which closet to the empty outside wall.
i am sorry for being so un-educated about this.
the speakers are facing away from the wall and the sub is furthest away.
i am sure it is the explosions/bass is what they are complaining about
#4 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,160 posts
  • Real Name:Robert
Posted October 04 2009 - 08:55 AM
Bass is the most difficult frequency to contain.  That's why when a 'boom car' drives down the street, you only hear the lowest notes of the music.  They may have the speakers pointed forward,backard or up but the sound travels every direction.  I'm just warning you that you may spend a sizable chunk of money on this and it does not help.
#5 of 7 OFFLINE   TonyD
TonyD
    Executive Producer
  • 16,239 posts
  • Real Name:Tony D.
  • LocationDisney World and Universal Florida
Posted October 04 2009 - 04:20 PM
Invite your neighbors over when you watch a movie, maybe they won't complain as much.
Also the other house is 20 feet away or are the houses connected?
facebook.com/whotony
#6 of 7 OFFLINE   paries
paries
  • 8 posts
Posted October 05 2009 - 02:20 AM
TonyD
the other house is not connected.
thanks
#7 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,160 posts
  • Real Name:Robert
Posted October 05 2009 - 03:17 AM
At my first house, my neighbor was 12' away at the closest point.  Now my closest neighbor is 50'.  The neighbor closest to the theater room is right at 100'.  He says it sounds like thunder in the distance when he is standing in his driveway but he can't locate the exact spot it is coming from.  He can't hear anything in his house.  That has to do with all of our houses having a brick exterior.  Mass is the only thing that can contain low bass.  Concrete and brick work best.
