Jump to content
JVC Announces 4.1-Channel Sound Bar Home Theater Systems
CEDIA 2009
  • Please log in to reply
No replies to this topic
#1 of 1 ONLINE   Ronald Epstein
    Studio Mogul
  • 42,988 posts
Posted September 10 2009 - 09:00 AM
Two systems debut– both with wireless subwoofer, one with Blu-ray player.
  WAYNE, NJ, September 10, 2009 – JVC offers a simple solution to top-quality home theater sound with the introduction of two new home theater systems.  The new TH-BA1 and TH-SB100 are both 4.1-channel systems that feature a low-profile front surround sound bar and wireless subwoofer.  Both systems combine sleek design and simple setup with performance that delivers clear dialog and convincing surround sound.   The sound bar is configured to fit neatly under a TV or can be wall-mounted.  Its front surround technology eliminates the need for rear speakers and the placement problems, clutter and extra wiring that comes with them.  A single cable connects the sound bar to a source (DVD or Blu-ray player) or TV via each systems’ two digital optical inputs and one analog input.  And to further simplify setup, the included subwoofer is wireless.  The TH-BA1 includes two components – the sound bar and wireless subwoofer, while the TH-SB100 adds a separate Blu-ray player to the package.   The black, low-profile sound bar includes four speakers, an amplifier and a sound processor. It also features built-in Dolby Digital, Dolby Pro Logic II and DTS decoding.  Total system power is 220W, with each speaker within the sound bar amplified and housed in a separate internal structure to prevent interference.  The virtual surround sound is based on JVC’s own front surround technology.  The two outboard speakers deliver the left and right channel information, while the middle two speakers each deliver center channel information plus the surround/left and surround/right channels.  The result is clear dialog and an immersive soundfield.   The subwoofer features a 6-5/6-inch (8cm) driver and is powered by its own built-in 100-watt digital amplifier.  2.4GHz digital wireless technology connects the subwoofer to the sound bar, and eliminates the need for a cable connection, providing simple setup and placement flexibility.   Power on/off, volume adjustment and source/surround mode selection can be operated using the provided remote control.
To the sound bar and subwoofer of the TH-BA1, the TH-SB100 adds a freestanding JVC Blu-ray player.  In addition to Blu-ray discs, the player offer playback of the AVCHD format, the widely used HD camcorder format. Other features include BD Live compatibility when used with USB memory.  Player connections include HDMI ver.1.3 with Deep Color and x.v.Color, USB Host, LAN for BD Live, component and composite video outputs, and analog, optical and coaxial audio outputs.  In addition to AVCHD, other playable formats are JPEG, MP3, WMA, Dolby Digital, Dolby Digital Plus, Dolby True HD, DTS and DTS HD.
  The TH-BA1 and TH-SB100 will be available in September for $399.99 and $699.99, respectively.   About JVC U.S.A. JVC U.S.A., headquartered in Wayne, New Jersey, is a division of JVC Americas Corp., a wholly-owned subsidiary of Victor Company of Japan Ltd. JVC distributes a complete line of video and audio equipment for the consumer and professional markets.  For further product information, visit JVC’s Web site at http://www.jvc.com or call 1-800-526-5308.
# # #   Specifications
Model name
TH-BA1 & TH-SB100
Main Speaker
Type
Full range bass-reflex, magnetically shielded
Full range
3-3/16 inch (8cm) Cone x 4
Power output
30W x 4
Decoder
Dolby Digital, Dolby Pro Logic, Dolby Pro Logic, DTS
Impedance
4 ohms
Dimensions (W x H x D)
35-3/8 x 4-9/16 x 3/3/16 inches (900 x 115 x 80mm)
Weight
11.46 lbs. (5.2kg.)
Wireless Powered Subwoofer
Type
1-way bass-reflex
Speaker
6-5/16 (16cm) Cone
Power output
100W
Impedance
3 ohms
8-1/2 x 13-7/8 x 10 inches (215 x 352 x 254mm)
Weight
12.7 lbs. (5.8kg.)
XV-BP1 Blu-ray Player (included only with TH-SB100)
BD Live™
Yes
Playable Media
BD-ROM/BD-RE/BD-R, DVD-Video/DVD-R/-RW, DVD +R/+RW, BD-ROM, BD-RE, BD-R, DVD-Video, DVD-R, DVD-RW (Video/VR), +RW/+R, CD/CD-R/-RW
Playable Formats (Image)
MPEG-2, MPEG-4 AVC (H.264), VC-1, AVCHD, JPEG Digital Still
Playable Formats (Audio)
LPCM, Dolby Digital/Dolby Digital+, Dolby TrueHD, DTS, DTS HD, MPEG-1/-2 L2, MP3, WMA
Video:
Video D/A Converter
12-bit/148MHz
NTSC – PAL Conversion
Yes
Deep Color
Yes
x.v.Color™
Yes
1080p Upscaling
Yes
Terminals
HDMI Digital Out (Audio/Video), Component, Composite, Audio Out, Analog 2ch, Coaxial Digital Output, Optical digital Output, USB Host (2), Network (Ethernet)
Power Consumption
Power On: 26W; Standby: Less than 1W
16-15/16 x 2-5/16 x 10 inches (430 x 58 x 253mm)
Weight
6.2 lbs (2.8 kg.)
* Design and specifications subject to change without notice.
 Posted Image
JVC THBA1 Soundbar
Ronald J Epstein
Home Theater Forum co-owner
 Click Here for the latest/hottest Blu-ray Preorders  Click Here for our complete Blu-ray review archive
 Click Here for our complete 3D Blu-ray review archive Click Here for our complete DVD review archive
 Click Here for Blu-Ray Preorder Release Schedule  Click Here for forum posting rules and regulations
Also tagged with one or more of these keywords: CEDIA 2009
