Jump to content
Need help with Lpcm
2 replies to this topic
#1 of 3 OFFLINE   Beefmaster
Beefmaster
  • 6 posts
Posted July 21 2009 - 03:55 AM
Hi,
This may sound like a stupid question, but I recently bought my first surround amp capable of playing HD soundtracks [a Denon AVC-A1HDA] .
My amp has no probs showing which soundtrack is playing on the display, DDTrue HD,DTS-MA etc but if I play a Lpcm track, it doesn't say Lpcm, instead it says multi channel.
Being my first HD amp I dont know if this is the correct description of the track showing on the display, can anyone with the correct info tell me if this is correct?
thanks for any help
#2 of 3 OFFLINE   Stephen Tu
Stephen Tu
  • 1,573 posts
Posted July 21 2009 - 04:30 AM
Normal.  You'll also get "multi-channel" for all the other codecs if you set your player to decode rather than bitstream.
#3 of 3 OFFLINE   Beefmaster
Beefmaster
  • 6 posts
Posted July 21 2009 - 05:10 AM
thanks for the advice, I found a similar problem with setting up my Denon 3800BD Blu-Ray player- set it for BD Audio out to "multi" for the blu-ray sound set-up and all codecs say 'multi-channel', but set the BD Audio out to HD Audio, and all codecs go to there normal names-DDtrueHD, DTS-MA, etc except for Lpcm which still says "multi-channel", but from what you said, thats normal anyway.
thanks again.
