Dave Delbridge
Grip
- Jun 3, 1999
Hi all,
I want to connect a pro audio interface (S/PDIF connector) to an Outlaw Audio 900's PCM ("coax") audio input. To my knowledge, these are compatible digital audio standards, right?
More importantly, I must make this connection between rooms with pre-existing wiring. Is this cable compatible with PCM audio:
Cable: Liberty Interflex 75 ohm Z-300 video cable @ ~50 ft.
The cable is unfinished on both ends. I've got some high-quality (gold contacts) Stinger RCA analog audio connectors that look like they'll fit this cable nicely. My only question is whether or not these will provide sufficient shielding for digital audio.
The rest is pretty straightforward:
Wall Plate: Leviton QuickPort 4-Port plate
Plate Connectors: Leviton QuickPort RCA Speaker Jack
LV40830B
Any advice is greatly appreciated.
Dave
LV40830B
Dave
