Jump to content
Help With Mac Networking...
  • Please log in to reply
7 replies to this topic
#1 of 8 OFFLINE   pitchman
pitchman
  • 1,847 posts
  • Real Name:Gary
  • LocationColumbia, MO
Posted May 08 2009 - 04:19 AM
I have an an Airport Extreme connected to an iMac via ethernet and several other devices that connect to the Extreme wirelessly (3 MacBooks, 1 Vista PC, Nintendo Wii, Sony PS3.) I have a Samsung LN46A850 TV that is about to be replaced by a Samsung LN46B750 and I am trying to figure out if it is possible to use an old Linksys WRT54GS wireless-G router as a wireless bridge for the TV (and hopefully the PS3.) In theory, if I can get the router to recognize the Airport Extreme, then I should be able to connect to the TV etc. via ethernet. The problem is, I don't know how to set up the Linksys on the Mac so it can recognize the Airport Extreme. I called Apple Care and they were some help but could not really address the Linksys configuration. When I called Linksys, they said I was out of warranty (which I am sure I am) and for them to help me further was going to be like $20 a minute for support, so I bailed. At this point, I am just trying to determine if my theory is correct, or if I am spinning my wheels. Should I invest in a dedicated wireless bridge or is this router capable of doing what I'd like it to do? Bear in mind that I am not all that technically versed, but I can generally figure out how to get from point A to point B. Any and all help is greatly appreciated!
Gary
#2 of 8 ONLINE   Sam Posten
Sam Posten
  • 19,075 posts
  • Real Name:Sam Posten
  • LocationAberdeen, MD & Navesink, NJ
Posted May 08 2009 - 07:05 AM
Should be able to do it. Put the uplink of the Linksys line connected to one of the Airports 3 lines, tell it to get its IP from the AP which gets its own set from the cable/dsl and you should be able to make it work.
I lost my signature and all I got was this Nutter t-shirt
HTF Rules
Classified Sales Rules
UV Sales New Clarifications
#3 of 8 OFFLINE   pitchman
pitchman
  • 1,847 posts
  • Real Name:Gary
Posted May 08 2009 - 08:18 AM
Thanks, Sam, but I think I'm still missing something. I am going from the AP line 2 out to the ethernet line in on the Linksys. If I turn Airport 'ON' on the iMac, I can see the Linksys router as an available network to connect to, but how do I get the Linksys to see the Airport Extreme?
Gary
#4 of 8 OFFLINE   Michael_K_Sr
Michael_K_Sr
  • 1,349 posts
  • Real Name:MichaelK
  • LocationChicago 'burbs
Posted May 08 2009 - 02:44 PM
I think I understand what you are trying to do...I tried something similar with my Slingbox and never did get it to work properly. Supposedly this is easily solved by having all devices on 802.11n, but I had no desire to upgrade my network right now. Kind of off topic...why are you dumping the 46A850? I love mine.
#5 of 8 OFFLINE   Eric M Jones
Eric M Jones
  • 398 posts
Posted May 15 2009 - 03:38 AM
Gary- I'm just trying to understand your goal here. Are you hoping to use the Linksys as an extender to the AE? Or are you wishing to set up dual networks so you can run the AE as an "N" and the Linksys as a "G"? Or do you have something else in mind? -EJ
 Visit my blog coregeek.net
#6 of 8 ONLINE   Sam Posten
Sam Posten
  • 19,075 posts
Posted May 15 2009 - 04:13 AM
Just tell it to get its own DNS via NAT and you should be good to go. It should treat the upstream router the same way it would a cable modem. You also need to turn off DHCP on the second router in the chain. This essentially turns it into a switch. Google 'Daisy Chaining Routers'.
HTF Rules
#7 of 8 OFFLINE   pitchman
pitchman
  • 1,847 posts
  • Real Name:Gary
Posted May 16 2009 - 04:03 AM
Thanks for the help guys! I ended up going in a different direction, and so far, it is working well. I called the local phone company and had them "unfilter" an existing DSL jack in the family room. Then, I disconnected the modem and Airport Extreme from my iMac and moved them to the new outlet. I plugged my new LN46B750 and the PS3 into the router and they both work great! The iMac and the Macbooks are all connected wirelessly and they do not appear to have suffered any significant performance hit - they still chug along at 10 meg plus speed. I am still trying to figure out how to get a Vista box into the equation, though. The only purpose this computer serves is that I use Windows Media Center to time-shift OTA TV programs. I would like to be able to use the computer's 750 gig hard drive as a media server for the TV and/or the PS3. Unfortunately, I have not been able to figure out how to do it... Finally, I have also been trying to figure out if there is any real benefit to buying and using one of those Nintendo Wii LAN Adapters from the Nintendo web site, or, if I should just stick with the built-in WI-FI.
Gary
#8 of 8 ONLINE   Sam Posten
Sam Posten
  • 19,075 posts
Posted May 16 2009 - 05:47 AM
Stick with Wifi
HTF Rules
