Jump to content
Subwoofer placement help
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Haris Ellahi
Haris Ellahi
  • 487 posts
Posted March 03 2009 - 09:53 AM
I am planning on getting either the SVS PB13-Ultra or the JL Audio Fathom f113.
One option for me is the place the subwoofer where the plant is (see the following two pics).
Posted Image
Posted Image
Or I can place the subwoofer where the bookshelf is.
Posted Image
My question is, if I choose the place the subwoofer where the plant is, will being very closely surrounded by sofas have any effect on the subwoofer's performance?
I read that near field placements are better due to the reduction of room modes at the listening position as the bass pressure wave hits your ears before the room boundaries have had a chance to effect the response. Is this true?
What would your recommendation be? Place the subwoofer in place of the bookshelf or should I place it where the plant is?
#2 of 5 OFFLINE   brandonchenry
brandonchenry
  • 129 posts
Posted March 03 2009 - 03:00 PM
I have a PB-12 as an end table, I like it. doesn't seem to muffle the bass at all.
#3 of 5 OFFLINE   Haris Ellahi
Haris Ellahi
  • 487 posts
Posted March 04 2009 - 03:18 AM
Is it also closely surrounded by sofas like in my pic?
#4 of 5 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted March 04 2009 - 12:06 PM
I would put it on the front wall(that the TV is on) if possible. THX recommends in front near the TV, when using one sub.
#5 of 5 OFFLINE   brandonchenry
brandonchenry
  • 129 posts
Posted March 06 2009 - 04:03 AM
yes but with a couch/overstuffed chair combo. Bass waves are long, this makes them very adept at passing through objects. you could even turn your sub around so that is is facing the wall and still have great sound. if you think about it, downward firing subs are a lot like facing your sub to your couch. Downwards fire just a few inched from the ground, but still produce amazing bass. I would go with the look that makes you happiest. another reason i like my sub as a end table to my couch is that at quiet volumes, I still feel a bit of the bass.
