Jump to content
Connecting HDTV to old stereo receiver
1 reply to this topic
#1 of 2 jd25
jd25
  • 1 posts
Posted February 01 2009 - 06:27 AM
I'm planning to buy an LCD HDTV. I have an older stereo receiver from the 90's that is hooked to couple of Bose speakers also from the 90's. Currently my CD player is connected to the receiver. I'd like to connect the HDTV to my stereo receiver (it has phono, CD, Tape1 and Tape2 ports) so that I can get the HDTV sound via the receiver/external speaker. I plan to connect hi-def cable DVR to HDTV via HDMI and my current DVD player to HDTV via red/white/black cables (that is it is connected to my current standard def TV).
What type of cable do I need to procure (other than HDMI cable) to connect the HDTV to the receiver?
Thanks!
#2 of 2 Joseph DeMartino
Joseph DeMartino
    Lead Actor
  • 8,302 posts
  • Real Name:Joseph DeMartino
  • LocationFlorida
Posted February 01 2009 - 02:29 PM
You are not going to get digital sound out of any of your components with the equipment you have. The best you are going to get out of your TV is analog stereo. Any decent red/white audio cable will transmit the sound from your TV to the receiver, although you could get pretty much the same effect by connecting all of your components directly to the receiver.
Joe
