Jump to content
Help choosing a reciever for paradigm monitors
4 replies to this topic
#1 of 5 OFFLINE   Robahr24
Robahr24
    Extra
  • 21 posts
Posted January 12 2009 - 12:41 AM
Need to upgrade my system. I plan on running paradigm 7's or 9's, which I will pick later, but I need a new reciever. Pioneer Elite VSX-01, VSX-03, VSX-90 or 91 Denon AVR 2808 or AVR 889 Onkyo SR606 or SR706 I want to spend $600 at the most and I can get the listed ones above for about that much, at the most maybe $650. I like the look of the denon and pioneer elites the most but know the onkyo can be a awesome budget reciever. Which should I pick?
#2 of 5 OFFLINE   itschuck2c
itschuck2c
  • 9 posts
Posted January 12 2009 - 12:03 PM
Harmon Kardon and Paradigm are made for each other.
#3 of 5 OFFLINE   Phil_O
Phil_O
  • 135 posts
Posted January 14 2009 - 03:44 PM
I use a a Denon 3805 for my Monitor 5's and CC370, with ADP 150's (old Paradigms) in the rear. It's sublime IMO.
Denon 3805 | Paradigm Monitor 5's front, CC370, ADP150 rear | Mirage BPS400 sub (the "Legend" I call it! - going strong since 1998!) | Toshiba SD DVD player | Tons of DVDs/CDs! | Nad c541i CDP | Main computer has 1080p 24" monitor, Logitech 5.1 system
#4 of 5 OFFLINE   Clinton McClure
Clinton McClure
  • 2,804 posts
  • Real Name:Clint
  • LocationCentral Arkansas
Posted January 16 2009 - 03:43 AM
Any of them should work as long as they can supply enough power. For years, I used a Yamaha RX-V995 to power my Monitor 9s, CC-350 and ADP-170s and it sounded great. Later, I added a separate 5-channel Anthem amp (while still using the Yamaha for processing) and the sound got even better.
#5 of 5 OFFLINE   LD9000
LD9000
  • 12 posts
Posted January 17 2010 - 03:36 AM
  I would definitely go with the Pioneer Elite models you mention, although I think they have already been replaced with newer models.   That would make finding one of the models you mention a sweet deal somewhere.   I currently own the VSX-03 and have mated them with Mirage speakers, which is an incredible combination.   The Paradigm are a warm sounding speaker - and you will need a warm receiver to go with them.   I know the Denons will sound fabulous with them as well --  but I found the best bang for the buck (plus many extras that the Denon doesn't offer ) lies in the Pioneer Elite line.
