Jump to content
Help Needed for Removing Jaggedness from. a Panasonic TH-46PZ800U
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Don
Don
  • 376 posts
Posted January 02 2009 - 09:31 PM
HDTV set how can i get rid of the Jaggedness on my set it just came out of the box. i'm trying to calibrate it by eye but no luck so far and my HD Essentials disc is packed away or missing plus i never calibrated using a disc before. also how high should this set be off of the floor. right now its sitting on the floor i don't want to mount it on the wall. but would like it to be up off of the floor. Don,
#2 of 5 OFFLINE   Gregg Loewen
Gregg Loewen
    Video Standards Instructor, THX Ltd.
  • 6,364 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted January 03 2009 - 01:28 AM
eye level for a starting point. switching to pro mode or movie mode should assist with jaggies. Find your calibration test.
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
#3 of 5 OFFLINE   Don
Don
  • 376 posts
Posted January 03 2009 - 04:53 AM
How can i get into Pro Mode or Movie Mode ?
#4 of 5 OFFLINE   Don
Don
  • 376 posts
Posted January 06 2009 - 08:58 PM
i have not the slightest ideal of what i did but i put all of the controls to 50+ then backing out or going thru more of the menus. i found a reset button on the screen i pressed the reset. and then turned it off figuring on working on it the next day. well i turned it on and there was a better picture then there was when it came out of the box. any ideals as to what i did ?
#5 of 5 OFFLINE   Michael TLV
Michael TLV
    THX Video Instructor/Calibrator
  • 2,909 posts
  • Real Name:Michael Chen
  • LocationCalgary, Alberta
Posted January 07 2009 - 03:02 AM
Greetings The instruction manual is your friend. regards
Michael @ The Laser Video Experience
THX Video Systems Instructor/ISF Instructor
Lion A/V Consultants Network - TLVEXP.com
