Need Help!!!!!!!!! (1 Viewer)
Itssimplymine
I had searched for weeks and have not found a system that suits my needs. I have a HDTV and a PS3 plus digital cable and would like to incorporate it all in one. Plus soon will buy a new PC and would like to use the surround if possible by bluetooth. I would like a system that has many features to have surround for all TV programs and gaming. USB maybe for music or for the PC. Also I would like a system to include speakers and if not have the receiver plus separate speakers to not exceed $600.00. Not to picky with color but black would be nice. I really cant find a good system that has the options i want.
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Don't want much do you
For less than $600, you are likely to find all the features you seek. Check out the Onkyo HT-S7100. It has many of the features you want and the price is within your budget.
bpickell
Brian
Well not exactly, If that comes with the TX-SR606 receiver It's not going to have USB and it is not compatible with an input from a PC or at least that is what my manual said don't know if it is true or not I haven't tried.
Also that system doesn't have Blue-tooth which he wanted (good luck finding that for your price range)
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Amazing what one missed word can do to a sentence
Yes, I meant to say it is NOT likely you will find all that you want with a $600 HTiB. For $600, the Onkyo is probably the best you can do. Thanks for correcting me.
Larsenv
