Jump to content
Dimming LED lights
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   the owl
the owl
  • 4 posts
Posted October 05 2008 - 05:18 PM
I have two 90 light sets of Sylvania LED Series micro-styled lights in clear(white). Does anyone know if there are dimmers that will work for them without ruining them? I've conflicting stories.. Also, can't find a number to call to check with them. Thanks
#2 of 5 OFFLINE   SherardP
SherardP
  • 222 posts
Posted October 06 2008 - 10:12 AM
Lutron Spacer System or Maestro will do the trick and look good installed.
#3 of 5 OFFLINE   Leo Kerr
Leo Kerr
  • 1,699 posts
Posted October 06 2008 - 10:37 AM
It depends on a lot of things. One of the problems with most electronic dimmers, particularly SCR-based, is that they "leak." And while the voltage leaking isn't high, it's enough that most SCR-type dimmers WON'T dim LEDs. On the other hand, if you were to put a dummy or ghost load on the dimmer as well, say, a 25-watt incandescent lamp or something like that, it might make it work out properly. It's something I keep meaning to try... Leo
#4 of 5 OFFLINE   chuckg
chuckg
  • 917 posts
Posted October 07 2008 - 03:56 AM
Leo is spot-on. If you can hide a 25 to 60 watt light bulb somewhere in a closet or whatever, then the "leak" through the dimmer will be absorbed (so to speak) by the bulb, so that your LEDs dim properly.
--ignore the man behind the curtain
#5 of 5 OFFLINE   the owl
the owl
  • 4 posts
Posted October 07 2008 - 07:38 AM
Thanks guys for your help. I'll let you know how things turn out.
